I have a brake master cylinder, which (from what I can tell from etka) fits a 92-95 Passat, and early mk3 golf/jetta 4cyl, pn# 357 611 019 b, it might fit other cars too I don't know.
I need to find a matching brake booster for this thing (bolt spacing is wider than any A1 booster I've seen) then I need to figure out how to mount it to my pedal cluster, if even possible. I swapped to 11"/8.9" disc brakes last fall, and my stock master cylinder is finally crapping out so I need to get this done.
Has anyone done this before? Will I need to change the pedal cluster or do I just need to modify mine?
