Re: minimal to no heat from my 16v, HELP!! (88GLI97B4wagon)
If your temp gauge is operating normally, then check your heater control valve. I just replaced mine ($10). They get all crapped up, then the cable gets harder and harder to move, then the clamp that holds the cable fails and you can't turn it on and off anymore.
Edit: It may be that not enough water is moving through to do much good, too. I would still start with the heater valve. Have you flushed the cooling system? There is some purple stuff ("Purple Power?") people have used to flush everything out that supposed to work real well.
[Modified by VWhombre, 9:44 PM 2-6-2002]
