I bought a 2002 Jetta 1.8t today for $800. The seller claimed all it needed was a battery and a starter. I was able to bump start it and get it home, but it smelled like it was running super rich. I hooked up the OBD-II scanner and got these codes:
P0300 - Random/Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
P1296 - Cooling System Malfunction
The car ran at a normal temperature on the 15 mile drive home, so I'm not worried about the cooling system code just yet. But I'm wondering if the bad battery is causing cylinder the misfires. I checked the battery, and it was at 11.9 Volts with the car off. It it possible the low voltage is causing the spark plugs on cylinders 1 and 2 to not work properly, causing the misfire?
