1 - 2 of 2 Posts
So the other day the son took my Jetta GLI out. Came back said the check engine light came on and started blinking and the car ran like crap.
I took it out to verify and everything seemed fine. Check engine light was still on though. Well driving back from in town and it did it to me. It just seems random that it misfires.
I put the Typhoon intake system on it. I wouldnt think that would be a issue to cause it.
I purchased the Ross-Tech vag-com reader and took the following faults.
I know for this year of Jetta, there was a recall on the coils. Could that be the issue?
Any help would be greatly welcome.
Thanks
Don
"NOOB"
Monday,27,February,2012,06:37:24:08854
VCDS Version: Release 11.11.2
Data version: 20120126
Chassis Type: 1K0
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 62 72
VIN: 3VWXJ71K76M681653 Mileage: 127580km/79274miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 B HW: 1K0 907 115 B
Component: 2.0l R4/4V TFSI 0030
Revision: --H10--- Serial number: VWZ7Z0E2428740
Coding: 0403010A18070160
Shop #: WSC 23411 444 85664
VCID: 254BC021ECFA27B
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 8
Mileage: 127151 km
Time Indication: 0
Date: 2000.00.00
Time: 16:31:49
Freeze Frame:
RPM: 1863 /min
Load: 30.6 %
Speed: 0.0 km/h
Temperature: 17.0°C
Temperature: -9.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.605 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Mileage: 127151 km
Time Indication: 0
Date: 2000.00.00
Time: 16:32:02
Freeze Frame:
RPM: 715 /min
Load: 27.8 %
Speed: 6.0 km/h
Temperature: 42.0°C
Temperature: 12.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.351 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 5
Mileage: 127219 km
Time Indication: 0
Date: 2000.00.00
Time: 15:10:06
Freeze Frame:
RPM: 1194 /min
Load: 40.8 %
Speed: 0.0 km/h
Temperature: 14.0°C
Temperature: 15.0°C
Voltage: 14.478 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Mileage: 127490 km
Time Indication: 0
Date: 2000.00.00
Time: 11:29:26
Freeze Frame:
RPM: 2047 /min
Load: 14.5 %
Speed: 18.0 km/h
Temperature: 66.0°C
Temperature: 5.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.605 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 408571B51398E23
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
Shop #: WSC 00000 000 00000
VCID: 67D78A295676F5B
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000160580
Coding: FF079E234004180001140000001400000018770B5C
Shop #: WSC 23411 444 59023
VCID: 2B5F36198A1E11B
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 23411
Component: Fehler Lin-Slave 02
4 Faults Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 101
Mileage: 127453 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 127453 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 62
Mileage: 127453 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.85 V
ON
ON
OFF
OFF
OFF
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 62
Mileage: 127453 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 13.75 V
ON
ON
OFF
OFF
OFF
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW: 8E0 035 593 E
Component: SDAR XM H03 0080
Revision: 00000000 Serial number: AUZ4Z7E0033083
3 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 6
Mileage: 82089 km
Time Indication: 0
Date: 2000.00.00
Time: 18:22:31
02633 - Antenna for Satellite Tuner
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 82
Mileage: 126539 km
Time Indication: 0
02788 - Internal Communications Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 254
Reset counter: 102
Mileage: 82089 km
Time Indication: 0
Date: 2000.00.00
Time: 18:22:30
Freeze Frame:
Bin. Bits: 00000010
Bin. Bits: 00000000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD03TCYZ
Coding: 0012627
VCID: 2E593F0DB90C643
Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002021
VCID: 7AF1C35D35C4783
Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 972 A
Component: KOMBIINSTRUMENT VDD 1212
Coding: 0023203
VCID: 30652175A338723
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057209225
Coding: 7D3F03600F1002
VCID: 2A51331D85E4083
1 Fault Found:
00484 - Vehicle Position Recognition Control Module (J603)
Freeze Frame:
Fault Priority: 2
Reset counter: 62
Mileage: 127131 km
Time Indication: 0
Date: 2000.00.00
Time: 14:23:35
Did this start when you installed the intake? If it did, go back to stock and see if it's fixed. I don't know what a "Typhoon" intake is, but if it doesn't use your stock MAF (including housing), get rid of it.
Start by checking the MAF and Lambda values. Make sure there are no vacuum/boost leaks.
1 - 2 of 2 Posts
