I have plenty fuel up top, but am getting a misfire starting around 6KRPM. Plugs are B6ET. I am installing a set of B6ES plugs and am closing the gap a little, starting around .025. What about going to a B5ES?
Quote, originally posted by rivethead » |
I assume you have decent plug wires? |
Quote » |
Under high boost levels you could blow the spark. |
Quote » |
Colder plug (same thing) |
Quote » |
or aftermarket ignition if you are not running one |
Quote, originally posted by Jefnes3 » |
NGK BKR 7E (copper plug 2 steps colder than ~stock N/A plug) Gapped to .022" -Jeffrey Atwood |
Quote, originally posted by Jesusloves20v » |
No, that plug is for x-flow, 16v's, vr6's, 20v's Youll need a 7 range plug in a NGK and do what Jeff said, gap that sucker down to .022 |
Why a cooler plug? From BDS (Blower Drive Service) info page. Forced induction is forced induction. Spark plugs should be one or two heat ranges colder than the recommended stock factory plug (never use extended tip spark plugs). The colder plugs need to be used due to the higher cylinder pressure created by supercharging; higher cylinder pressure means more heat. A cooler plug helps to keep pre-ignition levels down under high heat conditions (high boost). Since some plugs will actually glow after high boost, high use running. Plus running a cooler plug under high boost conditions helps to eliminate erosion of the tip over time. High densities (like those under boost) require more voltage to spark. Thus sometimes the smaller gap needed. This can be a detriment to optimum performance - You should run the widest gap possible. So the need for a more advanced ignition system at high boost levels. Modified by rivethead at 9:25 AM 9-12-2005 |
Quote, originally posted by German VR6 » |
how do you know if your blowing out spark?? |
Quote » |
Thanks for the ignition lesson but the question was how does a colder plug help a misfire under high boost. I know about heat ranges in plugs but I do not understand how that helps with misfires under high boost and maybe someone can enlighten my premadonna ego. |
