So I've been trying to help my dad with this GTI he recently bought, I scanned it with VCDS and it came back with this
Wednesday,30,December,2020,19:50:20:26133
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.1 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 327780km-203673miles
Address 03: ABS Brakes Labels:
VCID: 55F78AFD2D1737F3704-5184
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 C
Component: CLIMATRONIC C 1.0.0
Coding: 01000
Shop #: WSC 00001
VCID: 211FEE2D28DF8B535CC-5184
7 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00792 - A/C Pressure Switch (F129)
35-00 - -
00603 - Footwell/defroster Flap Positioning Motor (V85)
37-10 - Faulty - Intermittent
00797 - Sunlight Photo Sensor (G107)
30-00 - Open or Short to Plus
01271 - Positioning Motor for Temperature Flap (V68)
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 07 AIRBAG VW6 0202 0004
Coding: 12343
Shop #: WSC 00001
VCID: 3A2D3941A549F88B7D6-4B3C
1 Fault Found:
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 00001
VCID: 30391B69733532DBC32-51CE
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 925 D
Component: A4-KOMBIINSTR. VDO V01
Coding: 07232
Shop #: WSC 00000
VCID: 2A0D090155E9480B0D6-5160
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2728401
IMMO-IDENTNR: VWZ7Z0Y2728401
2 Faults Found:
00771 - Fuel Level Sensor (G)
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00001
VCID: 70B9DB69B3B572DB832-5160
1 Fault Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 62 Zentral-SG Komf. 0001
Coding: 00256
Shop #: WSC 00001
VCID: 06559DB1A1314C6B49E-4B1E
Subsystem 1 - Part No: Steuerger
Component: t Fahr. antwortet nicht
Subsystem 2 - Part No: 1J1959802D
Component: Beif. antwortet nicht
3 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
49-00 - No Communications
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0005
Coding: 01033
Shop #: WSC 42637
VCID: 1E65D5D119A1B4AB61E-51F2
2 Faults Found:
00668 - Supply Voltage Terminal 30
00855 - Connection to CD changer
End----(Elapsed Time: 04:55, VBatt start/end: 12.6V/12.0V. VIgn 11.9V)-----
We're fousing on the door controls as of now. Currently when trying tol unlock with key fob the lights blink and the alarmp beep goes off and the interior lights come on with key fob. Doors do not respond and after 20 secnds the alarm beeps a second time. When locking the door with the key, the lock module automtically unlocks the car the first time. Then after locked with key again it stays locked. If the battery is disonnected (or unplug window regulator momentrily) the windows and door buttons except for passenger window works for 5 minutes and then totally stops responding. The passenger side does not respond at all. Both window regulators have been changed, the same problems occur with orginals reinstalled. We've looked over wiring in the door jam, and all fuses re good. Any suggestions?
www.Ross-Tech.com
76
Coding: 01000
Shop #: WSC 00001
7 Faults Found:
35-00 - -
37-00 - Faulty
Coding: 12343
Shop #: WSC 00001
1 Fault Found:
Coding: 00008
Shop #: WSC 00001
Coding: 07232
Shop #: WSC 00000
2 Faults Found:
Coding: 00006
Shop #: WSC 00001
1 Fault Found:
Coding: 00256
Shop #: WSC 00001
3 Faults Found:
Coding: 01033
Shop #: WSC 42637
2 Faults Found:
