1 - 20 of 48 Posts
Are they going to offer the 1.8T in the MK V??? I know they will have a 2.0 T, but it only has a 16v head. I love the fact the 1.8T has a 20v head.
2020 Mercedes A250 4Matic
Re: MK V 1.8 T (juggernut)
Quote, originally posted by juggernut »
No
Re: MK V 1.8 T (Hajduk)
Do'h that sucks.... I mean the 2.0T sounds cool, but I wonder if you could fit a 20V head on it.
Since the 2.0T will be direct-injection, there is no room for the 5th valve.
well you wouldnt need room for it, becase you would be using a complete 20v head. Not trying to fit 5 valves on the 16 v head.
the 20V head won't fit which is why it is a 16V head in the first place.
Yea how do you know??? The 20v head fits on the current 2.0 ABA engine.
The current 2.0 does not have a fuel injector in the cylinder head.
Since the 2.0T will be FSI - you would have to convert the 20V head to FSI, which you could not do which is why they dropped the 5V per cylinder configuration since there is not enough room for 5 valves and an injector.
Banned
Re: MK V 1.8 T ([email protected])
Quote, originally posted by [email protected] »
You forgot a spark plug
Discussion Starter · #11 ·
Re: MK V 1.8 T (KARMANN_16V)
No I'm talking about taking a 1.8t and then yanking that new 2.0 FSI block and bolting it up to an entire 20V head. All I would use is the block for its larger size and lower compression.
but *why*
the fsi engines all get about 20% more hp and torque from 20% *less* fuel
therefore giving you the ability to build it that much more.
the 20v head is spiffy, but the 2.0t is better technology. The 1.8t has been around in audi cars for just over a decade.
Bring on the 2.0t
Discussion Starter · #13 ·
Re: MK V 1.8 T (XenoLlama)
Quote, originally posted by XenoLlama »
What are you talking about better technology?? 5v's per cylinder, show me any other car man that has done that. I like the flow characteristics of the 20v. Not sure how well the 16v will compare in flow, but I will find out eventually. Can some one give me a link to the new 2.0T engine??
Why go through all that trouble? Just stroke out the 1.8T block to 2.0L - there are several kits to do so.
Since the 2.0T has not been officially released in ANY VAG product - there is currently very little information or even pictures of it floating around.
Discussion Starter · #17 ·
No way, if you bore out the 1.8 you will make the cylinder side walls weaker then they already are, especially for a high boost application. I rather just have a solid 2.0 block, with the 20V head. Also what does the FSI stand for and does anyone know the specs of the engine at all, like what turbo they are going to use??
You don't have to bore out the 1.8T to got to 2.0l. If you are talking high boost applications - you will need to rebuild the bottom end anyway - since the 2.0T won't handle high boost any better than the 1.8T, since neither are designed for that application. FSI is just their nomenclature for direct injection. No specifics about the engine have been released yet.
Passat 2.8L 30v V6
A4/A6 3.0L 30v V6
S4/A6/Allroad 2.7L 30v BiTurbo V6
S4/A8/Phaeton/Toureag 4.2L 40v V8
Need more?
The 20V MIGHT fit the 2.0T block...once u change the cylinder head...the injection system also changes. It's like putting a 16v head on an ABA block.
1 - 20 of 48 Posts
