Hi all,
My linkage is hitting the flex coupling on the downpipe to the point where it is stuck in 4th gear when everything is assembled. I have read about people needing the correct bracket to accommodate the 1/2" of additional space (which i have) however I need about 3" more clearance to not only access neutral, but the gears on the other side.
The Car: 1987 Scirocco mk2, originally 8v automatic I bought with a 16v KR swap that I bought incomplete. It is paired with a 9A transmission. The previous owner sat on it and has no real knowledge of what is going on. I successfully got it running again after a cold 10 years but this linkage issue doesn't seem to be a problem I can find anywhere.
The downpipe is cut, there is no exhaust yet. Is it possible that is has sagged over time just hanging there?
Both the downpipe & Shifter Rod seem to line up correctly in the undercarriage channel so nothing is immediately obvious.
Has ANYONE ever seen or had this issue? Check these sweet sweet pics.
