Re: MK2 REAR DISC CONVERSION PROBLEM (Vdubs)
I looked around in ETKA at the prop valves, and it seems all Jetta cars got the beam mounted, and the base Golf cars got the inline versions near the MC, with the GTI Golf having the beam mounted like the Jetta.
There is a change noted in ETKA in 1989 (and is continued to be noted up through 1992), when the base Golf car started using the same prop valve as the other models. The break is shown as F 1G-K-005 316 <<>> F 1G-K-005 317, with cars up to number 316 using a smaller drum (180x30mm) and cars numbered 317+ getting large drums (200x40mm).
The drum size change is noted in the mexican Golf listing, and not in the USA Golf listing....both overlap in the 1989 year. For 1989 German Jetta, they came with both the small and large drums, with the change being for the RV engine models from car #280+, which got the larger drums. Either German Jetta got the beam mounted valve. The 1989 Jetta rear disc seems to be ABS only, but the 1986 german Jetta rear disc car uses the same beam mounted valve as the drum car (180x30mm, the larger wasn't available in 1986).
The beam mounted valve was shown as 191.612.151 and 357.612.151, and it seems the change was the mexican cars used the 357 part, and the US and german cars used the 191 part. The old number was 179.612.151.....the 179 changed to a 191 in 1985, with the MK2. The 191 then changed to a 357 for the 1989 cars from mexico.
It seems the check valves that go inline that Racer-X is talking about was used on the Mk1 cars, like the 79-84 German Jetta, Rab Conv, Scirocco, ONLY with the use of the 176.612.151 beam mounted prop valves.
Once the 176 number was changed to the 191.612.151 parts (1984), the check valves (113.611.191) were no longer needed. Since 1984, the 176 prop valve hasn't been used, the 191 and 357 valves have been used, and those are used on drum and disc cars both, and do not require the use of the check valves.
Whether the older 176 beam mounted valve was used on drum, disc, whatever during the MK1 years, I don't know...I know in 1984 it was gone, replaced with a 191 valve, and the check valves died with the 176 beam mounted valve.....cars then either got the 191 beam valve, or if it was a base Golf, it got load sensitive inline prop valves, one in each line, right at the MC. Later those died with the onset of the larger drums.
Basically, if you buy a beam mounted prop valve made after 1985, it'll work on both the drum and disc cars. If you find an old 176 beam mounted valve, it needs the check valves.
For the MK3 prop valves, they have one for the beam cars, one for the drum cars, but for MK2, both are the same. http://****************.com/smile/emthup.gif
Broke
