1 - 11 of 11 Posts
Where are you guys mounting your ECU's? ill be puttin my MS case in the interior somewhere , as well as the controller box for my Wb02 sensor (because i can). I was thinking in the center console cubby with grommets in the side of the console to run my wires out of.
P4v: Like my pic rory??
Banned
There is about a 2" gap between the fuse box and the side of the car which is where I always stick my haltechs. Its nice because your inches away from grommets through into the engine bay and less then inches away from switched power, ground, everything you need.
Re: Mk2 SEM installs / ECU/ECM mounting Q's (flyvwguy76)
i dont want to hide the ecm . ill see how my area works. i might be trying to put some MS harnesses that a PnP out aswell for a CE2 box so im seeing where ppl are mounting there ecu's.
Re: (801pete)
Quote, originally posted by 801pete »
exactly where my sds is!
Discussion Starter · #9 ·
Re: (ValveCoverGasket)
Quote, originally posted by ValveCoverGasket »
i mounted mine in the raintray, but that car doesnt get driven in bad weather...although the ecu is fully covered by the rain tray plastic..
yea i want all aluminum boxes inside the car , thats how i get my jollies
Discussion Starter · #11 ·
just did a miata where we put it on the back of the glovebox, might be space in a mk2 if you didnt have a/c
i dont think i want to run it to the other side. I really wanna throw em in the center console.
1 - 11 of 11 Posts
