1 - 5 of 5 Posts
I was told to have one key in the ignition and one in the door hold it to unlock it beeps 3 times then push a button on the fob it should sound once or twice then hold the key to unlock until it beeps 3 times again is this right???
sort of right.. here are the steps:
you need 2 keys.
1: switch ignition to ON position.
2: step out of vehicle and close all doors and hatch/trunk.
3: using second key in driver's door, turn key to UNLOCK position and hold for approx. 10 seconds or until alarm horn sounds 3 times.
4: press unlock/disarm button on first remote (alarm horn will briefly sound once to confirm programming).
5: repeat if necessary for second remote.
6: repeat if necessary for third and forth remote.
7: turn and hold the key in the driver's door lock to UNLOCK position (alarm horn will sound 3 times within 10 seconds).
8: step in vehicle and switch ignition OFF.
I am having trouble getting In the car to beep when I put a lock on the new fab it will beep when I hold the key in the drivers door in the unlocked position for 15 seconds three times when I let it go to neutral I try to push the unlock button on the remote but nothing happens
2011 Jetta Sportwagen S 2.5L; 2021 Hyundai KONA SEL
10 years in between previous posts, so you might be better of to ask in the MK3 forum. I've never had an MK3 so I have no idea what works for older generations.
On the B5.5 Passat I had I used exactly the method @tdawg21 posted back in 2009.
If you have an MK6, then I can give you the procedure as outlined in the MANUAL. What's your pleasure?
1 - 5 of 5 Posts
