1 - 8 of 8 Posts
Re: MK3 /R32 look install????? (iwanaleya)
ok this is not rocket science !!! the celis or angle eye lights get wired into the running lights . i used a volt meter and and i used the side indicators with wire tapind wich i bough a radio shack for a buck. the wireing is like this if it is not a gti you will have one brown wire one yellow and one white . the brown is the ground. the other two are hight and low beam .
Re: MK3 /R32 look install????? (DubbleTrubble)
Quote, originally posted by DubbleTrubble »
I already Have the euro harness hooked up and I am having problems with my high beams
Be a little more specific, whats your problem with the high beams?
1 - 8 of 8 Posts
