1 - 2 of 2 Posts
Discussion Starter #1
Hello guys,
Could use some help, I have a 2001 GTI 1.8T fully built running a pte5558gen turbo on maestro eurodyne software.
My issue is it hits a limiter at around 140mph in 5th gear. Just cuts out like a governor on a stock car.
I did 2 things that may have cased this buy I'm not sure if thats the cause.
1. Swapped to 6spd from the old 02J (6speed option selected in eurodyne software)
2. I swapped out the speedo cluster to a new unit because old cluster went.
Any idea where the speed governor is? In the actual ecu, cluster etc
Thanks
Discussion Starter #2
Just to update this, speed governor in maestro quick setting fixed the issue. Just in case anyone else has this problem.
1 - 2 of 2 Posts
