1 - 8 of 8 Posts
Forum Elder
Thought for sure it was going to ping like a mofo...stoked. It's freakin' hot too....
Before I rebuilt the motor, it would ping under load when it was hot outside and about 220-230 oil temp. That was with my 16-row setrab..now I have a 19 row and oil temps have not been above 208/195 water. Peeeeeeerfect imho.
I'm thinking the carbon buildup may have had something to do with the previous pinging issue. Also, my EGR valve is not seeing vacuum under load. Need to replace the solenoid valve.
Re: Mk4 Head Gasket, 256's, 91 Octane, and GIAC chip...NO PING! (SLC4EVER)
Yes, this is correct. Everyone that I know that has a "well kept/built" VR6 is running this gasket with no problems at all.
I would bet big money that anyone who has issues with running a MK4 gasket already had "other" issues before the head gasket install.
Bill
Re: Mk4 Head Gasket, 256's, 91 Octane, and GIAC chip...NO PING! (billyVR6)
Wow, congrats sir. I'm glad you could make this work. I wanna see some numbers on this thing when you've broken it in a bit.
Forum Elder
solenoid valves goes tonight so you can please the cali emissions folks..
I have the exact same setup. No pinging on agressive street driving.
I do get pinging at the track w/ 91 so I mix in some race gas and it goes away. (100+ outside Temp, 290+ Oil Temp w/ oil cooler)
Forum Elder
Discussion Starter · #6 ·
Quote, originally posted by billyVR6 »
Thought for sure the 91 octane would have a major impact.
Quote, originally posted by BilingualGringo »
You and me both! Only 900 more miles to go.
Quote, originally posted by yellowslc »
Saweet! You da man...Uncle Emissions isn't!
Quote, originally posted by maxrev »
Great info! Thanks!
Man, yall need to move away from that 91 stuff.
Come to VA and come across some 94 pump gas. http://****************.com/smile/emthup.gif
Forum Elder
Discussion Starter · #8 ·
Re: Mk4 Head Gasket, 256's, 91 Octane, and GIAC chip...NO PING! (BilingualGringo)
Tell me about it. It's hard to beat the weather though...
1 - 8 of 8 Posts
