Mk4 Headgasket on Mk3 Vr6?
1299 Views 4 Replies 4 Participants Last post by  24v
hey i acutally meant this.. not the intake manifold.. i hear that this will raise compression.. and just wanted to know if it was a worth while mod..? in addition to porting and polishing the head.. and adding cams .. well thanx
DL
1 - 5 of 5 Posts
2
Re: Mk4 Headgasket on Mk3 Vr6? (DarkLite13)
Hell yes http://****************.com/smile/emthup.gif its worth every penny cause its a cheap mod that you could get at least 15hp from easy. Makes your car rev so much more and feels much more lighter great mod for the money especially if you have head work and cams
See less See more
Re: Mk4 Headgasket on Mk3 Vr6? (benzivr6)
BTW it also raises the compression from 10:1 to 10:6. and also while the head is off change all the timing chain guides and any wear parts.
yah i say do it...if i wasnt going turbo...i would throw on the mkIV headgasket, do some cams, and change the timing guides also...do the titanium valve springs also...good luck
quote:[HR][/HR]BTW it also raises the compression from 10:1 to 10:6. and also while the head is off change all the timing chain guides and any wear parts.[HR][/HR]​
10:6 compression would be like 1.66666666666:1 compression
the engine wouldnt run
See less See more
1 - 5 of 5 Posts
