MK4 Turbo'd 2.0 options. What size?
483 Views 6 Replies 7 Participants Last post by  bergenvr6
I'm getting a TT system, but I'm not sure as to go with the 2.25" or the 2.5". I'm not going too crazy with the system, only about 9PSI. Which size sounds more reasonable for a daily driven/ some autocrossing turbo'd AEG?
Remember that this system is for a 2.0 8V with a turbo kit, not a 1.8T punched out to 2.0 liters. Thanks!
1 - 7 of 7 Posts
Re: MK4 Turbo'd 2.0 options. What size? (vertigobora)
I'd say go with the 2.5"...turbos need as little backpressure as possible, regardless of the engine that you have.
GO AS BIG AS you can get....i recommand 3" or even larger custom ones
Re: MK4 Turbo'd 2.0 options. What size? (kyokoris)
TT 2.5" on mine http://****************.com/smile/emthup.gif
See less See more
Re: MK4 Turbo'd 2.0 options. What size? (Cosmic631)
I had a TT but was not extremely happy with it for 2 reasons. One related to the TT and 2 not related.
1. Around the resonator area, it's 2.25 inch not 2.5
2. I had the stock cat
Last week, I changed my cat to a 2.5 inch high flow and removed the TT resonator and custom made a 2.5 inch straight pipe to replace it. All I can say, is wow, what a difference. On top of that, my EGT's dropped by another 150-200 degrees.
Re: MK4 Turbo'd 2.0 options. What size? (TheSpilDog)
See less See more
Re: MK4 Turbo'd 2.0 options. What size? (jettanjax)
2.5 definitely
1 - 7 of 7 Posts
