1 - 2 of 2 Posts
I have a 1991 Jetta Coupe and a rolled 2000 Jetta VR6. I want to swap that VR into the MK2. I know that the long-block is the same as a MK3 block so the engine will bolt up. I am concerned about the wiring. Is there somebody that did this swap? I need to know who can modify the harness for me to make this swap work?
Any comments or additional info appreciated
Re: MK4 VR6 into MK2 - need some info! (fahrvergnugenvw)
One thing I can tell you is that the ECU in MK4's speaks to a module in the instrument cluster (something to do with the immobilizer), so you'll have to swap the Mk4 cluster as well.
Talk with Eurobahn, he not only did a Mk4 VR6 into a Mk2 but it was 24v!
1 - 2 of 2 Posts
