Posted also in the Vag-com Diagnostics Forum,
Update: fixed by changing abs coding from 21128 to 21122
Wondering if any one can point me in the right direction on this one, i converted my 06 GTI to awd using 08 r32 ABS Module, G419 and Haldex assembly. The awd works but i cant get passed DTC:01044 Control Module Incorrectly coded. stored in the ABS Module..
anybody got advise on this?
TIA
Tuesday,13,September,2016,10:01:09:19149
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 16.8.0.3
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WVWEV71K06W134920 License Plate: JEFF GTI
Mileage: 143040km-88880mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 22 25 42 44 46 52 55
VIN: WVWEV71K06W134920 Mileage: 143040km-88880miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
22-AWD -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (CRZ) Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 B HW: 1K0 907 115 B
Component: 2.0l R4/4V TFSIb 02 1448
Revision: --H14--- Serial number: VWZ7Z0F3305587
Coding: 0403010A180F0160
Shop #: WSC 50563 001 104857
VCID: 2541E9A6ECABCB6AF3-8070
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 01279 785 00200
VCID: 72EBC2FA6DE5ECD2A6-8026
1 Fault Found:
01044 - Control Module Incorrectly Coded
003 - Mechanical Failure
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 68DFA0925B39160208-803C
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002329313
Coding: 078F0F214004150000140000001400000018770B5C0000
Shop #: WSC 52460 001 104857
VCID: 377D33EE460749FA51-8062
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 52460
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 142877 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04HH6/
Coding: 0013644
Shop #: WSC 01269 785 00200
VCID: 397935D670135F8AA7-806C
Subsystem 1 - Part No: 000 000 000 000
Component: BF-Gewichtsens. 000 0000
Subsystem 2 - Serial number: 6332MSME0E1F653ET
Subsystem 3 - Serial number: 6342MSME0E16741CH
Subsystem 4 - Serial number: 6352QSME0742484BH
Subsystem 5 - Serial number: 6362QSME033A147BH
Subsystem 6 - Serial number: 63727SME09125872.
Subsystem 7 - Serial number: 63827SME0926084D3
6 Faults Found:
02511 - Control Module for Seat Occupied Recognition (J706)
004 - No Signal/Communication - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
00592 - Seat Belt Switch; Passenger (E25)
010 - Open or Short to Plus - MIL ON
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00591 - Seat Belt Switch; Driver (E24)
010 - Open or Short to Plus - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
VCID: 7AFBEADA35959492EE-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 972 E
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007203
Shop #: WSC 00001 067 57207
VCID: 346704E25771A2E274-8060
1 Fault Found:
00438 - Fuel Supply Sensor 2 (G169)
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106125020E
Coding: FD0F03000F0000
VCID: 2A5B1A9A85B5E412DE-807E
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0002
Revision: 00001000 Serial number: 1225223T18TD02
VCID: 7DF1E1C624BBA3AACB-8028
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 36633EEA410DB0F24A-8062
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 4312
Shop #: WSC 50563 001 1048576
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2375
Coding: 0001077
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 336507FE527FA5DA6D-8066
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AS HW: 1K0 959 433 AS
Component: 02 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 939006885103281B0904058FB0080A0480A440
Shop #: WSC 00000 785 00200
VCID: 01099D365843C74AAF-8054
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 209
Mileage: 142877 km
Time Indication: 0
Date: 2000.00.00
Time: 23:19:47
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001077
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E7C4E217F1E2E2B4-8020
4 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation
00497 - Sensor for Vehicle Leveling; Rear
00496 - Sensor for Vehicle Leveling; Front
01537 - Vehicle Level Sensor; Supply Voltage
007 - Short to Ground
End-------------------------(Elapsed Time: 01:45)--------------------------
TIA
www.Ross-Tech.com
Revision: 00H13001
Coding: 0021128
1 Fault Found:
1 Fault Found:
Coding: 00063445
Shop #: WSC 52460
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 142877 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.70 V
ON
ON
OFF
OFF
OFF
Coding: 0013644
6 Faults Found:
Coding: 0002022
Coding: 0007203
1 Fault Found:
Coding: 0000001
Coding: 0001077
1 Fault Found:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 209
Mileage: 142877 km
Time Indication: 0
Date: 2000.00.00
Time: 23:19:47
Coding: 0001077
Coding: 0000003
4 Faults Found:
