1 - 6 of 6 Posts
Is there a way to turn off fault detection for the city lights on a MkIV?
I installed one LED for testing but receive the following error code:
Sunday,13,May,2007,22:30:14:12513
VAG-COM Version: Release 704.1
Address 09: Cent. Elect.
Control Module Part Number: 3C0 937 049 D
Component and/or Version: Bordnetz-SG H37 1002
Software Coding: 24018E2B4004151F4E14000000140000000973075C
Work Shop Code: WSC 06506
Additional Info: 1K1955119C Wischer VW350 013 0402
 ÝH
02395 - Parking Light Right Front (M3)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 42036 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
Re: Mk5 LED City Lights - possible? (Theresias)
Yesterday I was making changes to that byte and switched the rear parking light mode (by mistake). So tonight I fixed that and made the change you requested using the below code. However the change didn't help, aby other ideas?
Monday,14,May,2007,18:35:39:12513
Software Coding: 24018E2B4004151F4E14000000140000000973095C
 ÝH
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 42036 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.00 V
OFF
ON
OFF
OFF
OFF
Re: Mk5 LED City Lights - possible? (dschein)
Your original code was:
24 01 8E 2B 40 04 15 1F 4E 14 00 00 00 14 00 00 00 09 73 07 5C
Recommended code was:
24 01 8E 2B 40 04 15 1F 4E 14 00 00 00 14 00 00 00 09 73 05 5C
Your last posted code was:
24 01 8E 2B 40 04 15 1F 4E 14 00 00 00 14 00 00 00 09 73 09 5C
Sometimes LEDs in the City Lights won't work. Please double check your coding, and consider the JamStrait LEDs, which seem to work regardless of coding.
JamStraits can be purchased at AutoZone.
Modified by Tim Birney at 8:13 PM 5-14-2007
Re: Mk5 LED City Lights - possible? (Tim Birney)
Quote, originally posted by Tim Birney »
Tim,
I changed the Rear Parking Light setting by mistake before my original post. So after fixing my misate the original code was:
24018E2B4004151F4E140000001400000009730B5C
Sebastian's suggestion was to turn off cold diagnosis for the Front Parking Lights, the result was:
It appears that the LED's I'm using won't work so it's off to the store for a set of JamStrait LEDs.
Thanks!
The only stopper on the JamStraits is their outside diameter.
Compare the over all size to a stock w5w/194 bulb before you buy.
They do look nice in the Side Markers...
1 - 6 of 6 Posts
