1 - 3 of 3 Posts
1981 rabbit caddy
Hello All!
ive in the process of swapping a brm tdi off a 2006 tdi Jetta into my mk1 caddy!
ive done a lot of custom work, I’ve welded the floor pan and firewall from the mk5 to the mk1.
Using heater core, dash, steering rack, almost everything into the mk1.
now the problem that I have, I’m using the full harness from the mk5, my transmission is from a mk4. Which has a speed sensor in the transmission. The mk5 I believe uses the abs signal to get the speed to the cluster!
Is there anyway I can get the speedo to work on a cluster with no abs?
if your interested in some pics, progress checkout the build on Instagram sebby81caddy!
Any help would be greatly appreciated
1 - 3 of 3 Posts
