1 - 2 of 2 Posts
I have these two codes just did intake manifold and injector seals and a carbon clean also had to replace a coolant pipe under the manifold my epc light comes on and the car bucks hard and then it will drive but you can feel the lack of power I also filled the tank thinking maybe the low fuel level would go away it didn’t don’t care that much about that more so about my epc light and the code for the speed sensor anyone ever had this happen ?
Discussion Starter · #2 ·
I did a throttle body reset and all the codes and problems went away I just wanted to update this post for anyone who has this issue happen to then I used my snap on scanner
1 - 2 of 2 Posts
