For a while now we have been putting out articles about common issues with the TSI and FSI engines.
These are some common things you should look out for on your Volkswagen MK6 GTI 2.0T.
Listed below are the articles we have published to date. We are planning to put out articles regularly and we will update this thread as new articles are published. We hope you check them out and find something helpful or interesting on them.
2.0T TSI Common Problems
- - 2.0T TSI Evap Purge Valve - "Check Gas Cap Light"
- - 2.0T TSI Fuel Injector Failures
- - 2.0T TSI Cold Start Misfires and Carbon Build Up
- - 2.0T TSI Misfires and Ignition Coils and how to check
- - 2.0T TSI High Pressure Fuel Pump (HPFP) Problems
- - 2.0T Timing Chain and Timing Chain Tensioners
- - 2.0T TSI PCV (Crankcase ventilation valve) Causing a Whistle noise
- - 2.0T TSI Diverter Valve (DV) Causing Boost Leak/ Torn Diaphram
- - 2.0T TSI Intake Manifold for code P2015
- - VW Audi DSG Transmission and Service Info
- - 2.0T TSI Rear Main Seal Failure
