1 - 20 of 612 Posts
Discussion Starter #1
I want to get heavier steering in my Golf, but the dealership won't do it, as VW won't allow code tweaking. The local dealership recently had a campaign where they retrofitted the drive profile button and the software, but it turned out it's only for DSG cars. So I'm stuck with steering that I find too light.
The local car forums here list guys who have the needed HW and SW to tweak the coding but naturally there's no rating on these guys.
My question is: How difficult is it to tweak the power steering settings on these cars? I understood it's behind some lock code that you need to know before you can access the setting. Can you mess up something if you don't know what you're doing? I wouldn't want to take my car to someone who messes up my car and doesn't offer any kind of warranty for the job.
Discussion Starter #3
Thanks. What are the chances of messing something up when trying to tweak the settings? I found a guy who has the gear needed, but no experience in this specific tweak. I sent him the Ross-Tech link and he said it looks promising.
It's easy to tweak with an OBDEleven, but it resets the next time you start the car up. I'm interested in whether doing it using these other methods makes it stick.
Check my DIY here for info.
So wait, i dont have a OBD Eleven but does this mean all coding done by that device gets reset the next start up? I was thinking of getting one but not if its needs to be redone every restart.
I just traded in my 2015 GTI SE DSG for a 2018 GTI SE DSG a week ago and was about to do some of the mods like Mirror Dip and Window closing with Key Fob and some of the mods i had done on my 2015 didn't work or couldnt find modules etc because apparently the MK7.5 has just enough new stuff that it some of it doesnt work.
I did a ton of searching but alomost everything I found was for just the Mk7 not 7.5. I'm a novice at most of this so i'm not about to go playing around and break something but was able to find some help on the MKVII Golf R page. so here's what i found:https://forums.vwvortex.com/showthread.php?8927457-MK7-5-Golf-R-VCDS-Tweaks
I haven't tried any of these yet and some are Golf R specific but if any of you have some that you've worked out i figure this would be a good place to put them all and save others a lot of searching. there are also a couple that i'm looking for if anyone else has some ideas
-Rain Closing that works (I know right?)
-Stop Start Default Off turn on with Button
-Removing the NAR Headlight restrictions to the Dynamic lighting
-Anything else you think is cool.
Originally posted by AWDWagon on the above thread:
"** Note that the coding below works on my new 2018 (built 01/18) vehicle with the updated modules **
DRLs and fog lights as Coming/Leaving Home
09 - Central Electrics
Adaptation – 10
16-Security code 31347
Aussenlicht_Uebergreifend-Coming Home Leuchten -> "Fog light" (default “Low beam”)
Brightness of license plate lights
Adaptation - 10
(6)-Leuchte25KZL HA59-Dimmwert AB 25
Set to "60" - Default setting is 127
Disable the little red led's on the side of the taillights
09-Central Electrics
10-Adaptations
(1)-Leuchte27NSL RC6-Lasttyp 27 to "not active" (default: "43-allgemeine LED")
Disable Orange LED in Front Headlight
Module 09 - Central Electrics
10-Adaptations
Leuchte26NSL LA72 - Lichtfunktion A 26 - change from “Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)” to “nicht aktiv”
Mirror Dip on Reverse
Check this post
Fan Level Display on Auto (Climatronic)
08 Air Conditioning
07 Long Coding
Go to Byte 11
Enable Bit 6
Retain Heated Seat Setting
08 Auto HVAC
Adaptation and change the following:
"retention of the seat heater level driver" to active (default is 10 min.)
Refuel Quantity
Amount of fuel used since the last fill up (refuel quantity)
17 Instruments
Long Coding
Go to Byte 10
Enable bit 4
Windows up/down with remote
Adaptation - 10
ZV Komfort-Comfort opening-> “active” (default: Not active)
ZV Komfort-Comfort closing-> “active” (default: Not active)
ZV Komfort-Funk Komfort oeffnen-> “active” (default: Not active)
ZV Komfort-Funk Komfort schliessen-> “active” (default: Not active)
ZV Komfort-Menuesteurung Komfortbedienung einstellbar -> “adjustable”
In H/U, Car - Setup - Open and Close - Conv. opening (all windows or drivers window)
Roll windows up/down with hand in handle, thumb on dimple
Adaptation - 10
Schlusse_Zugang-und Startberechtigung-Kessy Komfort oeffnen-> "active" (default "not active")
Windows Up After Car is Turned Off
09 Central Electrics
Adaptations
ZV Komfort
Freigabenachlauf FH bei Tueroeffnen Abbrechen -> “Not Active” (default: Active)"
Please feel free to add anything that you have personally tested.
Anyone know how to increase the idle speed? I've read you can increase it by 50 rpm or so. I'm thinking it might help for taking off in first gear smoothly, among other things.
I was also wondering if it was possible to change the settings for the ESC To the same ones as in the Golf R and possibly add “Race” to the mode selection like on the R.
Here are a couple more that I did on my 2018 Golf R. For some reason - I can't get the horn to beep on lock - it only beeps the second time I hit lock on my keyfob. Works for unlocking though.
Disable Door Open/Ignition Tone
17 Instruments
Adaptations
Ignition active message; Trigger
Change to "No display" (default value: driver's door)
German translation for this is.....
STG 17 (Schalttafeleinsatz) auswählen
STG Anpassung -> Funktion 10
Zündung aktiv Meldung; Auslöser
ändern auf "Keine Anzeige"
Disable Seatbelt Warning
17 Instruments
Adaptation Channels -> function 10
Select disable seatbelt warning
change to "yes" (default: none)
I have VCDS (bought the cable a long time ago when I purchased the MK6) and had tried a few tweaks. A strange thing is that some of the settings work intermittently, and I can't figure out what causes it to work or not work. For example, the staging setting of the dials was set on as default by the dealership (I presume), but works sometimes (usually when the car has been off for a long time); the last wipe of the windshield after using windshield washer works very infrequently, etc. In the MK6, the tweaks would work consistently.
I also tried the speed sign recognition setting, but it doesn't seem to work in US models, either because it doesn't work or because our signs do not follow international standards. I think the only tweaks I have now are the mirror dip (but I don't use it because the mirror doesn't go back to the original position), dial staging, and the last wipe. Thanks OP for starting this thread and will definitely follow it.
Found another one on another thread.
Change ESC button values:
03 ABS > 07 Coding > Long COding > Choice 29 byte (last one)
Hex Values
05 - ESC ON/ASR Off/ESC OFF
06 - ESC ON/ESC SPORT / ESC OFF
09 - stock
Did anyone ever figure out how to disable the North American headlight restrictions on the mk7.5 since the module you used to go into to do it on the mk7 is no longer applicable to the mk7.5?
1 - 20 of 612 Posts
