Re: (gti1647)
I took some pictures of my car, with the head liner removed, so you can see what has to be taken out. (My car is a 92 golf MKII, no sunroof. so there may be a few things different if u have a jetta or a sunroof).
I was able to remove everything with just a philips screwdriver and a 17mm socket, and some one to help me pull the headliner out.
Start by removing sun visors, holy sh!t handels and the dome light. there is also a clip above the drivers side door, where the holy sh!t handle would be, so remove that too.
Remove both A pillar covers, theres one screw in each and they just slide out.
Remove both B pillar covers, and the seat belts. again theres just one screw and then pull it out. i put the seat belts back on so that i could drive it.
Remove both C pillar covers, and seat belts. I didn't take them out, i just lossend them and pulled them back enough to slide out the head liner. Its much easier to just remove them if u dont want to damage your headliner tho. also theres a strip of plastic on top along the back of the roof. it just pulls out.
Once u have all that out the only thing holding it up should be the weather stripping and 3 clips along the middle. take the clips out first, (i had to break mine to get them out, just buy new ones at the dealer ship, $1.25 each.)
Then get some one to hold it up while you pull the weather stripping out, it just pulls out, then carfully pull the headliner out the back hatch. and your good.
should look like this when its out...
This is just to show how thin they really are. and its made out of a really brittle light weight material.
You can buy a spay can of headliner glue for $10 at CT or anyother auto shop.
This is the glue I used and it worked great so far.
I just have to pick out a new fabric and ill take more pics when im finished.
So good luck and have fun.
Modified by gti1647 at 10:07 PM 8-31-2008
