I took my 2000 Jetta VR6 with the Eibach Pro-System installed in to get an alignment the other day. This is my first alignment since installed a month or so ago. I went to Pep Boys (maybe a mistake) since it's right next to where I live. Since I got my car back, the wheel needs to be slightly to the left to go straight. It has no pull and the toe seems to be okay.
I took it back in and they put it on the rack and told me that the "wheel cannot be straightened since I have a lowering kit." They said the caster is different from side to side and it causes the car to pull slightly to one side. That they say is why the wheel is off.
My question is can't the steering wheel's position still be adjusted in relation to the wheels without changing the overall toe value to make the wheel "centered?"
Here are the alignment values after it was done:
Left Front Right Front
Caster: 7.54 deg 7.86 deg
Camber: -1.02 deg -0.33 deg
Toe: -0.03 deg -0.02 deg
Edit: sorry the spacing between the values didn't carry through
Modified by MacDalund at 5:59 PM 11-18-2004
