Frequently Asked/Answered Questions
MKIV FAQ
Wheels and Tires
Wheel Database - David Cretney
Problem: Pitting Wolfsburg wheels here - pooz01wolfsburg
Peeling wheels petition for MKIV VW's - SilverGTi01
Wheel Weights - leftcoastvw
FAQ-Wheel Tech
FAQ-Tire Tech
Wheel Bolt Pattern and Offset - Weapon-MKIV
Stock tire sizes (recommend to keep speedometer as accurate as possible)
195/65-15 (15's will not fit r32s 337s, 1.8t GLIs, or 20AEs)
205/55-16 (16's will not fit r32s)
225/45-17
225/40-18
235/35-19
Suspension
Read before lowering your car
What is a swaybar and what does it do? - Daemon42
Suspension Tuning
Transmission
How to Change Transmission Fluid - with pics 4/15/04
Brakes
Brake Forum
Brake Upgrade Kits for MK4 Platform - eggroller
Lighting
Lighting FAQ
Bulb List
What Bulbs do you need?
Where can I find 12 to 10 pin adapter for OEM HIDS
How do I adjust my headlights
Fuel & Oil related
DIY Writeup: Fuel Filter Replacement 4_09_04
Oil that meets VW's 502.00 Requirement
1.8t
1.8t FAQ
Which Chip for the 1.8t? - 18turbo.com
Aftermarket Foglights for the 1.8T
Blow-Off-Valve VS. Diverter Valve
VR6
12v VR6 FAQ - Boost Inside & need_a_VR6
The mysterious VR6
Which Chip for the VR6? - NeoJetta
What epoxy should I use to repair my coilpack? - Fantomasz
What is rattling under the hood/what's up with the intake manifold? - adg44
TDI
TDI FAQ - Deception
2.0L
2.0l FAQ
My 2.0 Burns Oil/ Excessive Oil Consumption
General
VW Coil Pack/Ignition Guide (all models)
Coil packs and ignition coil problems
DTC/Error codes post - ducelectronics
DTC/Error codes - nianmuzik
Body Work/Body Styling/Body Kits
Jolf and Getta Conversions
What mods won't void my warranty? - VW TANK
Jack Pads - rgrubb
Light Bulb Guide - Converted_VW
How do I jack up my car? - hungalicious
The DownShifting Debate - Ze
Cullen's OEM parts resource - Cullen
Is oil consumption normal? - jonjacob
Window Regulators
The MAF Thread - john green
How do I remove my door panel? - Jetta
How do I remove my door panel? - Golf / GTI
How do I eliminate door panel rattle?
Squeeks and rattles - Helicon Twist
Single Wiper conversion - Boostin20v
Audi A4 Avant rear wiper with working rotating rear washer - Helicon Twist
Camera Mounts - Stewz-GTI
Where to get Security Torx bits for MAF removal - VgRt6
99.5 - 2004 Paint Codes - Red Pocket Rocket
Fuse Listings
Manual HVAC Bulb replacement (climate control lights don't work, or work intermittently)
Optima RedTop Battery Install - flashback
Coolant Migration Explained - GT17V
Other FAQ's
Other FAQ Resource - mkivresource
John Abella's MK4 VW FAQ - abella
Transmissions, Syncros and Short Shift Kits - CorradoTDI
Various informative posts made by Daemon42 and linked in one place - Daemon42
Side Skirt Links - burningmoney97
Jetta
Jetta body kit options and links to manufacturers - forum discussion
Grill Options for the Jetta - TurboBmaNN
What is a Bora? Bora is the European name for the Jetta. When the Jetta first cam out, it didn't do well on the market in Europe, so they renamed it to change it's image. The MKIII Jetta was the Vento, the MKIV is the Bora
GTI
What does GTI stand for? Gran Turismo Iniezione (Grand Touring Injected)
What does GLI stand for? Gran Luxe Iniezione (Grand Luxury Injected)
PhotoShop
How do you Photoshop your pictures?
Modified by rs4-380 at 1:28 PM 12-14-2004
Modified by BRM10984 at 5:01 PM 12-26-2004
Modified by BRM10984 at 3:47 PM 1-4-2005
MKIV FAQ
Wheels and Tires
FAQ-Wheel Tech
FAQ-Tire Tech
225/45-17
225/40-18
235/35-19
Suspension
Suspension Tuning
Transmission
Brakes
Brake Forum
Lighting
Lighting FAQ
Bulb List
Fuel & Oil related
1.8t
1.8t FAQ
VR6
The mysterious VR6
TDI
TDI FAQ - Deception
2.0L
2.0l FAQ
General
Jack Pads - rgrubb
Window Regulators
Fuse Listings
Other FAQ's
Jetta
GTI
PhotoShop
