Good morning all -- looking for some guidance on diagnosing the problem I am experiencing with my 2005.5 Jetta 2.5 (200k miles).
Problem(s):
1) Doors lock when arming alarm, except the front passenger side door. Front passenger door will remain unlocked 99.9% of the time, however if I open the door, the alarm will sound.
2) Driver-side window will roll down, but not always roll back up. As such I never roll it down. Rear driver window will not roll down at all regardless of using driver or rear-driver switch. Passenger windows will roll down.
(Notes: I have replaced the driver door wiring harness once before and have another harness at the ready if I need to do that repair again; I will update with functionality of door lock switches -- but all have power to them as they are backlit).
I have checked the driver door wiring harness numerous times to see if it was a poor connection. It is not.
I have run VCDS and will paste the results below, areas of note highlighted in red.
Question: In your experience, is this a door module issue, or possibly the vehicle electrical control system control module, comfort system central control module, or all of the above?
I have read a number of VW community posts about similar problems, but am just trying to get some insight before I choose a path to go down.
Much thanks!
-Bill
VCDS
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine Labels: 06A-906-032-BGQ.lbl
Part No SW: 06A 906 032 QC HW: Hardware No
Component: 2.5l R5/4V G 6654
Revision: 00000000 Serial number: VWZ7Z0E1827413
Coding: 0000003
Shop #: WSC 00066 000 00000
VCID: 6FB8D9C04B96DE3FC43-803A
No fault code found.
Readiness: 0000 0000
VCDS
Self-Diagnosis Log
Page 2
Address 02: Auto Trans Labels: 09G-927-750.clb
Part No: 09G 927 750 AS
Component: AQ 250 6F 0649
Coding: 0000008
VCID: 025E80746804C3573BD-8056
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
VCID: 3A2E389440544B9723D-806E
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6C82CECC7A802527E11-8038
VCDS
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 C HW: 1K0 937 049 C*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000000047805
Coding: F40D8E02400418000014000000140000002077035C
VCID: 2F3819C08B169E3F843-807A
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
4 Faults Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
01024 - Rain Sensor (G213)
014 - Defective - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
01333 - Door Control Module; Rear Left (J388)
VCDS
Self-Diagnosis Log
Page 4
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD01MMEG
Coding: 0012627
VCID: 2E0604C48C1C97378F5-807A
Subsystem 1 - Part No: 1K0 959 339 B
Component: BF-Gewichtsens. 006 0003
Subsystem 2 - Serial number: 6332MSME0958605AE
Subsystem 3 - Serial number: 6342MSME09160D6DK
Subsystem 4 - Serial number: 6351HSME063B4649A
Subsystem 5 - Serial number: 6361HSME06324315Z
Subsystem 6 - Serial number: 63727SME065A0052V
Subsystem 7 - Serial number: 63827SME065A1636+
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AB HW: 1K0 953 549 AB
Component: J0527 010 0045
Coding: 0010041
VCID: 72BED0B458A4F3D72BD-8026
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 971 C
Component: KOMBIINSTRUMENT 3HL 2120
Coding: 0021203
VCID: 2B000DD0BF0EE21FA8B-807E
VCDS
Self-Diagnosis Log
Page 5
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001051210353
Coding: 3F3F03420F1002
VCID: 290CF7D8B5F2F00F5A7-807C
2 Faults Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 60
Reset counter: 141
Mileage: 257056 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:18
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 181
Mileage: 260992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:32
VCDS
Self-Diagnosis Log
Page 6
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 HW: 1K5 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 0371356TNV5803
VCID: 78AAE29C3ED89987159-802C
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 243034 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:18
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 243034 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:18
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2120
VCDS
Self-Diagnosis Log
Page 7
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2339
Coding: 0001271
VCID: 36362CA4744CAFF7C75-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
VCID: 303A1ABC962881C79D9-8064
VCDS
Self-Diagnosis Log
Page 8
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AT HW: 1K0 959 433 AT
Component: KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 13100F880106281B0906050FA0080F0490A540
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
4 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 231
Mileage: 242608 km
Time Indication: 0
Date: 2000.00.00
Time: 13:34:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 45
Mileage: 257056 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:19
00931 - Locking Module for Central Locking; Rear Right (F223)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 259969 km
Time Indication: 0
Date: 2000.00.00
Time: 22:44:43
VCDS
Self-Diagnosis Log
Page 9
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 181
Mileage: 260992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:32
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456
Component: 08K Audioverst. 0003
Revision: 00002000 Serial number: 00000000013042
VCID: 698CB7D87572300F9A7-803C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001271
VCID: 372821A0734656FFDC3-8062
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 A HW: 1K0 035 180 A
Component: Radio ZSW 011 0016
Revision: 00011000 Serial number: VWZ5Z7E6101193
Coding: 0010010
VCID: 1E66D404FCBC07B73F5-804A
Address 62: Door, Rear Left
Cannot be reached
VCDS
Self-Diagnosis Log
Page 10
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Component: Tuer-SG 021 2416
Coding: 0000144
VCID: 323E10B49824B3D7EBD-8066
End----------(Elapsed
Problem(s):
Much thanks!
-Bill
VCDS
Coding: 0000003
VCDS
Self-Diagnosis Log
Page 2
Coding: 0000008
Coding: 0021122
VCDS
Self-Diagnosis Log
Page 3
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
4 Faults Found:
VCDS
Self-Diagnosis Log
Page 4
Coding: 0012627
Coding: 0010041
Coding: 0021203
VCDS
Self-Diagnosis Log
Page 5
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Reset counter: 141
Mileage: 257056 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:18
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 181
Mileage: 260992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:32
VCDS
Self-Diagnosis Log
Page 6
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 243034 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 181
Mileage: 243034 km
Time Indication: 0
Date: 2000.00.00
Time: 18:41:18
VCDS
Self-Diagnosis Log
Page 7
Coding: 0001271
VCDS
Self-Diagnosis Log
Page 8
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 231
Mileage: 242608 km
Time Indication: 0
Date: 2000.00.00
Time: 13:34:33
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 45
Mileage: 257056 km
Time Indication: 0
Date: 2000.00.00
Time: 12:21:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 113
Mileage: 259969 km
Time Indication: 0
Date: 2000.00.00
Time: 22:44:43
VCDS
Self-Diagnosis Log
Page 9
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 181
Mileage: 260992 km
Time Indication: 0
Date: 2000.00.00
Time: 10:21:32
Coding: 0001271
1 Fault Found:
Coding: 0010010
Cannot be reached
VCDS
Self-Diagnosis Log
Page 10
Coding: 0000144
