1 - 7 of 7 Posts
Discussion Starter #1
I had the spare tire on for a few days & I was thumbing through my VAG-COM & I came across "Deactivate TPMS" So I checked the box.
Now I have a new tire back on my car & I can't find the loaction where I made the TPMS change. So now I have this low tire pressure light on my dashboard & I want to reactivate my TPMS so it will go away!
Anyone know where the TPMS is located in VAG-COM?
Re: MKV GTI - TPMS System - HELP (rippie74)
On your Hard Drive there is a folder where VCDS (VAG-COM) is installed.
Right Click on the VCDS ICON on your Desktop, and go to Properties.
This will tell you where VCDS is installed. Go to that location, open the Folder for VCDS, then open the Sub-Folder for DEBUG.
All of your before, and after coding is in there, with Date and time(s) of the changes.
That should get you started.
(My first guess is that you went into the Can Gateway and disabled it in that location)
Discussion Starter #3
Re: MKV GTI - TPMS System - HELP (Tim Birney)
Quote, originally posted by Tim Birney »
Thank-You Tim I will try that....
Yea I was messing around & forgot how I made this change.
Discussion Starter #4
Well I did that & this is what I found:
Address 46:1K0 959 433 CT recoded (Long Coding) from 12900788510300242804058FB0080A04889C00 to 12900788510300242804058FB0080A0488BC00 Saturday,03,January,2009,20:04:26:15276
What does that mean?
Quote, originally posted by rippie74 »
12 90 07 88 51 03 00 24 28 04 05 8F B0 08 0A 04 88 9C 00 to 12 90 07 88 51 03 00 24 28 04 05 8F B0 08 0A 04 88 BC 00
BYTE 17 changed, BYTE 17 is undefined, and Unknown.
Full Auto-Scan please?
Discussion Starter #7
I got it Tim, Thanks http://****************.com/smile/emthup.gif
1 - 7 of 7 Posts
