1 - 8 of 8 Posts
Discussion Starter #1
I tried to do the indirect method of TPMS when I put on my new wheels, however it looks like I have the older module. Is it possible to enable it another way? Or is it possible to retrofit the later ABS module into my car?
Code:
Wednesday,06,March,2013,07:21:44:45684
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 1K0
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 62
          65 72
VIN: 3VWDJ71K58M003148   Mileage: 144790km/89968miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: VWX7Z0G43NA7QF
   Coding: 0403010A1C070160
   Shop #: WSC 00066 000 00000
   VCID: 36690CEA41F509A8CB0
1 Fault Found:
008825 - Leak in Air Intake System
               P2279 - 002 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 144581 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:18:37
             Freeze Frame:
                    RPM: 753 /min
                    Load: 18.0 %
                    Speed: 0.0 km/h
                    Temperature: 59.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1408
   Revision: 05108020    Serial number: 00001004080468
   Coding: 0000020
   Shop #: WSC 04940 001 00001
   VCID: 1C3DFE42DF19B3F8DD4
No fault code found.
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0021122
   VCID: 73EFF5FE12075C802CE
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6ED9E48A79257168C30
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
   Component: Bordnetz-SG     H54 2202
   Revision: 00H54000    Serial number: 00000000662815
   Coding: 17050E234004150F870000000F0000008019940364000100000000000000
   Shop #: WSC 00066 123 12345
   VCID: 71E3FFF6681B6E90DE2
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 280607 020  0501
   Coding: 00038805
   Shop #: WSC 00066
Address 0F: Digital Radio        Labels: 8E0-035-593-SIR.lbl
   Part No SW: 8E0 035 593 N    HW: 8E0 035 593 N
   Component: SDAR SIRIUS     H08 0150
   Revision: 00000000    Serial number: AUZ4Z7H0414161
   Coding: 0000000
   VCID: 346D36E257891BB8F54
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 136274 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:55:30
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AB    HW: 1K0 909 605 AB
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M026RTK
   Coding: 0013889
   VCID: 6CDDEE824F398378ED4
   Part No: 1K0 959 339 F
   Component: BF-Gewichtsens. 007 0005
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012121
   VCID: 81032F36D8BBFE10AE2
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K6 920 974 A    HW: 1K6 920 974 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G43NA7QF
   Coding: 0023403
   Shop #: WSC 25019 444 67490
   VCID: 326130FAAD9D1588E78
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 190507F1000854
   Coding: ED817F071013021002
   VCID: 30653AF2A391279891C
Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T2LV104
   Coding: 0000003
   VCID: 397307D670EBE6D0262
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1216
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000019878526
   Coding: 0001205
   VCID: 3B7F1DDE7AD7D4C034E
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 02069 000 90108
   VCID: 356B0BE65CF302B0C2A
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 CT    HW: 1K0 959 433 CT
   Component:    KSG PQ35 RDK 052 0221
   Revision: 00052000    Serial number: 00000000000000
   Coding: 1B900F880186083F2D04058DF0880F0488DC00
   VCID: 840D2622C7A9EB38854
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456 A
   Component: 08K Audioverst.     0005
   Revision: 00003000    Serial number: 00000000145227
   VCID: 2A51289A854D5D485F8
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000529078602
   Coding: 0001204
   VCID: 3C7D1EC27FD9D3F83D4
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000003
   VCID: F4ED76E29709DBB8B54
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
   Component: J388   TUER-SG HL   1120
   Revision: 12006001    Serial number: 00000001718141
   Coding: 0001168
   VCID: 3E7914CA69C5C1E8130
Address 65: Tire Pressure        Labels: 3C0-959-433-65.lbl
   Component:    RDK              0450
   Coding: 0100101
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
   Component: J389   TUER-SG HR   1120
   Revision: 12006001    Serial number: 00000001755622
   Coding: 0001168
   VCID: 3F8769CE6ECFC8E0186
End   ---------------------------------------------------------------------
http://forums.vwvortex.com/showthread.php?6021100-Can-ABS-style-TPMS-be-enabled
As in above thread, thought that my '06 was too old too. Coded, drove about 40 miles (20 of it motorway), went for coffee, came back, and the icon was there on switch on. Only got the Ding! when I enabled it in VCDS coding.
Seems you don't have to have a MK60EC1. Just that some controllers react differently to this coding change
Your risk if you do change your coding! Just saying it worked for me:p
Discussion Starter #3
Hey I think I got it working. I changed my coding from 0021122 to 0004738 in the ABS module. Subtracting 16384. I disabled the direct tpms in the other controllers. The light came on as soon as I hit the do it! button. I will update this thread in a few days after it adapts. Thanks for the word doc!
Let us know how you got to your figures? I'll then add to Word doc. If you've got any pix, screen shots, they would help others too
Cheers
Discussion Starter #5
I'm going to shoot you an email with some screenshots. No fault codes were found.
Discussion Starter #6
It works! I dropped it from 38 to 28, it dinged in 2 miles. I do have run-flats so that may delay it due to them holding their shape better. The group 42 in basic settings reset the system as well.
Good stuff! Reading about in the UK forums, VW want £30 for enabling this. So that's another £30 saved off the original cost of a proper VCDS cable...
VW don't enable it coz they want to sell you their wireless TPMS system plus fitting. Alright, 7k1 to 5 does tell you lots more info in your MFD but for me I just want to know about a possible flat tyre situation before it goes to the rim. I've got a tyre pressure gauge :p
Thanks your e-mail, will add to help file:thumbup:
Hi guys. I'm in a situation trying to import my wife's 2008 GTI from Canada to the USA. TPMS is required for USA import.
I used the instructions to change the code (BlakeH00 post), and the dash light for TPMS comes on.
But, the local VW dealer stated that they didn't see the change in the scan tool they use.
Here is a video showing the dash indicator. https://photos.app.goo.gl/zEqrvipbSvaeHYoG2
Wouldn't this mean that TPMS is on and active for the GTI?
Would there be any reason why a dealer couldn't validate that the Indirect TPMS (via ABS) is working?
We are frustrated and would like to complete the import... but until we can get a VW dealer on our side to confirm TPMS, we won't be able to get VW of America to give us the required letter of conformity that US Customs and Border Patrol requires for compliance with DOT/NHSTA.
Uggh.:confused:
1 - 8 of 8 Posts
