1 - 12 of 12 Posts
We recently installed our Auxiliary Low Pressure Fuel System upgrade on a customers 2012 VW MKVI GLI 2.0T TSI. Some of you may be following his build thread, patrick02. Link to thread: http://forums.vwvortex.com/showthread.php?5573872-GLI-AirLift-BBS. The car is fitted with the APR Stage 3+ kit, integrated engineering connecting rods, and an otherwise stock motor. Before our fuel system, the most we were able to push out of the car was 443 wheel horsepower on 104 oct gas. Once we got more fuel, the car was able to put down 473 wheel horsepower along with MS109 gas. That's a peak 30whp gain, and even bigger gains in other areas of the power band!
We have more plans in the future for this car such as: Built head w/ Ferrea valve train components, intake manifold, and a high pressure fuel system solution. APR is currently working on the high pressure fuel solution and we are hoping for a release within the next few months so we can break the 500 horsepower barrier!!
Below you will find a video demonstrating how the fuel system works in action, and the dyno graph :cool:
THIS IS NOT ADVERTISED HORSEPOWER NUMBERS & THIS IS NOT AN OFF THE SHELF KIT. THIS IS A USP MODIFIED CAR WITH THE STAGE 3+ KIT TO ACHIEVE THESE POWER FIGURES!!
CLICK HERE FOR MORE INFO ABOUT THE USP MOTORSPORTS AUXILIARY LOW PRESSURE FUEL SYSTEM
CLICK HERE FOR MORE INFO ABOUT THE APR STAGE 3+ TURBO KIT
Holy crap :eek:
Honest question - was there an issue (disconnected, something else, etc.) with the in-car boost gauge on the first run, as the needle really did not move. On the second, it moved quickly and stayed there.
Nice numbers either way, just wondered about the gauge?
Discussion Starter · #10 ·
To be honest, im not completely sure why that was. I know they were messing with a bunch of stuff while the car was on the dyno. So they must have disconnected and capped the vacuum line for some reason on that run.
1 - 12 of 12 Posts
