1 - 10 of 10 Posts
I get a brief mild moaning sound when turn left or right, with the wheel turned 90 degrees, but stops as I complete the turn, and rotate the steering wheel some more. Is that a symptom os CV joint failure?
Re: Moaning when turning? (Grand Admiral Thrawn)
My car does this too, I've been assuming that it's just the wheels rubbing the wheel-wells.
just a suggestion and I overlook things too.....but did you check the power steering fluid?
Re: Moaning when turning? (GTI0109)
Quote, originally posted by GTI0109 »
mine was doing a mild mone at slwo speeds lock to lock fliud was low, check it http://****************.com/smile/emthup.gif
Modified by protijy337 at 8:40 AM 5-21-2004
Quote »
Yes she does that sometimes
This happens to me from time to time but only when it has just rained out and the car is wet.
Re: Moaning when turning? (VolksPike)
Quote, originally posted by VolksPike »
pervert! hahaahah...i see through your subliminal messages!
Re: Moaning when turning? (b.schulz)
Could be the mystery tranny TSB that no one can produce a copy of! The detection signs are a moan on full on turns that sounds like a wheel bearing gone bad.
1 - 10 of 10 Posts
