1 - 12 of 12 Posts
Is there anyone on this forum with a modern enough engine to run this with out it pissing out of every oil seal??? :laugh:
good for you Andy
See if i do it, I'm an a-hole.
I have two valvetrains that I'd like to send to MOBIL ONE, from my racing days....kablooey!
Scored cams, galled buckets, ground head caps. Totally attributable to 10-30 Mobil One.
They claim they are the WORLDS LEADING motor oil.
I read this as Wal-Mart sells more of this runny water than anyone.
Me...I'll stick to CASTROL EDGE 5w50...over a quarter of a million miles in an actual SCIROCCO.:wave:
78rabbit1.5LGP & 82rabbitpickup1.6DGC
was going to ask the same thing
didnt wanna be the first a-hole to make the point
i run 15w-50 in my engines
C.A.F.E and oil weights
There is only one reason that companies make 0 weight oils...and to be sure isn't for your engine longevity.
All car companies have to sell cars based on C.A.F.E CORPORATE AVERAGE FUEL ECONOMY
You can bust out the door a lot more expensive high profit Corvettes and Cadillac V series when you can counter balance that with crapping out a half million higher mileage HHR's.
So...by lowering the initial start-up weight of the oil, the gas mileage goes up by say .2 mpg....multiply by 17 million cars, thats a lot of gas savings/profit ratio.
Not one oil manufacturer/car manufacturer has ever published ANYTHING {that I've ever seen} that says how much wear and tear this piss-weight oil does to your engine...what do they care? By the time your 35k mile warrantee is up...it's on you!:thumbdown::thumbdown::banghead:
Thanks for proving my point!
See below. 0w-40 is specifically NOT recommended for VW's
Please note that...to be fair here...VW does not recommend ANY, repeat ANY 0 weight oils...even in NEW warranteed cars....bet you can guess why.
Interestingly, the brand I use and have used with great results, IS recommended.
Volkswagen Oil Standard 502.00 / 505.00 / 505.01 Approved Oils
Volkswagen 502.00/505.00/505.01 Approved Oils
Last updated: 19.01.2010
Current as at: 20.06.2010
Search:
Manufacturer Product SAE Class VW Standard
Adamol Adamol Multitop PDI SAE 5W-40 50200/50500/50501
Agip Agip 7004 SAE 5W-40 50200/50500/50501
Agip Agip Formula Prestige SAE 5W-40 50200/50500/50501
API IP Sintiax 505 Exclusiv SAE 5W-40 50200/50500/50501
Aral Aral Tronic 431 SAE 5W-40 50200/50500/50501
Beijing Tongyi Petroleum Monarch SAE 5W-40 50200/50500/50501
Blu Lubricants Inc Blu Synthetic -Technician Series FS SAE 5W-30 50200/50500/50501
BP BP Visco 5000 C SAE 5W-40 50200/50500/50501
BP BP Visco Special V SAE 5W-40 50200/50500/50501
Car Jack Car Jack GPD SAE 5W-40 50200/50500/50501
Cartechnic CARTECHNIC Motorenöl Pumpe Düse SAE 5W-30 50200/50500/50501
Castrol Castrol Edge 5W-40 A3/B3 SAE 5W-40 50200/50500/50501
Castrol Castrol Edge A3/B4 SAE 5W-40 50200/50500/50501
Castrol Castrol Edge Turbo Diesel SAE 5W-40 50200/50500/50501
Castrol Castrol GTX Magnatec SAE 5W-30 50200/50500/50501
Castrol Castrol GTX Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec C3 SAE 5W-30 50200/50500/50501
Castrol Castrol Magnatec Diesel B4 SAE 5W-40 50200/50500/50501
Castrol Castrol Magnatec Professional B4 SAE 5W-40 50200/50500/50501
Castrol Castrol Magnatec Professional C3 SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional 505 01 SAE 5W-40 50200/50500/50501
Castrol Castrol SLX Professional B4 SAE 5W-30 50200/50500/50501
Castrol Castrol SLX Professional OE SAE 5W-30 50200/50500/50501
Castrol Castrol TXT 505 01 SAE 5W-40 50200/50500/50501
Chevron Havoline Ultra S SAE 5W-40 50200/50500/50501
Delek Delkol Motorsynth TDI SAE 5W-40 50200/50500/50501
Engen Petroleum Engen Formula 505.01 SAE 5W-40 50200/50500/50501
Eurol Eurol Turbo DI SAE 5W-40 50200/50500/50501
FL Selenia Selenia K Pure Energy SAE 5W-40 50200/50500/50501
FL Selenia Selenia Multipower C3 SAE 5W-30 50200/50500/50501
Fuchs Fuchs TITAN GT1 SAE 5W-40 50200/50500/50501
Fuchs Fuchs TITAN GT1 PRO FLEX SAE 5W-30 50200/50500/50501
Fuchs Fuchs TITAN GT1 PRO GAS SAE 5W-30 50200/50500/50501
Fuchs Fuchs TITAN Supersyn PLUS SAE 5W-40 50200/50500/50501
Galp energia Galp Energy Ultra LS SAE 5W-40 50200/50500/50501
Galp energia Galp Formula 505 SAE 5W-40 50200/50500/50501
Ginouves York 848 SAE 5W-40 50200/50500/50501
Gulf Gulf Formula ULE SAE 5W-40 50200/50500/50501
Gulf Gulf Formula ULE SAE 5W-30 50200/50500/50501
Hunold EUROLUB Cleantec SAE 5W-30 50200/50500/50501
Igol Igol Profive 505.01 SAE 5W-40 50200/50500/50501
Igol Igol Profive Gold SAE 5W-40 50200/50500/50501
Igol Igol Profive Silver SAE 5W-30 50200/50500/50501
LLK Finland OY Teboil Diamond SAE 5W-40 50200/50500/50501
LLK Finland OY Teboil Diamond Diesel SAE 5W-40 50200/50500/50501
Lotos Lotos Quazar SAE 5W-40 50200/50500/50501
Lotos Lotos Quazar C3 SAE 5W-30 50200/50500/50501
Lotos Lotos Traffic Diesel 505.01 SAE 5W-40 50200/50500/50501
Lotos Lotos Traffic PRO 505.01 SAE 5W-40 50200/50500/50501
Meguin megol Motorenoel New Generation SAE 5W-30 50200/50500/50501
Mitan Mitan Alpine PD SAE 5W-40 50200/50500/50501
Mobil Mobil Super 3000 XE SAE 5W-30 50200/50500/50501
Mobil Mobil Syst S ESP SAE 5W-30 50200/50500/50501
Mobil Mobil Syst S Special V SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Gold SAE 5W-30 50200/50500/50501
MOL MOL Dynamic Prima SAE 5W-40 50200/50500/50501
Motul Feu Vert 505 01 SAE 5W-40 50200/50500/50501
Motul Motul 8100 X-clean SAE 5W-40 50200/50500/50501
Motul Motul Specific 505 01 502 00 505 00 SAE 5W-40 50200/50500/50501
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-30 50200/50500/50501
Norsk-Pennsylvansk DynoCat Neutron CXS SAE 5W-40 50200/50500/50501
Oest Oest Gigant LS Plus SAE 5W-30 50200/50500/50501
OJS OJS Econo-Veritas XV SAE 5W-40 50200/50500/50501
Ölwerke Julius Schindler OJS Econo-Veritas XV SAE 5W-40 50200/50500/50501
Paz Lubricants & Chemicals Ltd Top Paz SAE 5W-40 50200/50500/50501
Pennzoil Pennzoil Platinum European Ultra Diesel SAE 5W-30 50200/50500/50501
Pennzoil Pennzoil Platinum Low SAPS SAE 5W-30 50200/50500/50501
Pentosin Fairline Motorenöl SAE 5W-40 50200/50500/50501
Pentosin Pento High Performance II SAE 5W-40 50200/50500/50501
Pentosin Pentosynth HC SAE 5W-40 50200/50500/50501
Petro China Kunlun Tianrun SAE 5W-40 50200/50500/50501
Petro China Kunlun Tianyuan SM SAE 5W-40 50200/50500/50501
Petronas Syntium 5000 XS SAE 5W-30 50200/50500/50501
Prista Oil Prista Ultra Plus SAE 5W-40 50200/50500/50501
PTT Public Company Limited Performa Euro Syn SAE 5W-40 50200/50500/50501
Quaker State Q Diesel Plus SAE 5W-40 50200/50500/50501
Quaker State Q European Engine Ultra Diesel SAE 5W-30 50200/50500/50501
Quaker State Q Synquest Low SAPS SAE 5W-30 50200/50500/50501
Quantum Quantum PD Diesel SAE 5W-40 50200/50500/50501
Quantum Quantum Platinum SAE 5W-40 50200/50500/50501
Raloy Raloy Genuine Engine Oil SAE 5W-40 50200/50500/50501
Ravenol Ravenol VPD SAE 5W-40 50200/50500/50501
real real,-Quality GPD SAE 5W-40 50200/50500/50501
Redoil Italia Challoils Ultrasynt SAE 5W-40 50200/50500/50501
Repsol Repsol Elite Evolution SAE 5W-40 50200/50500/50501
Repsol Repsol Elite TDI SAE 5W-40 50200/50500/50501
Rothen Oil Rothen Extrasynth SAE 5W-30 50200/50500/50501
Rowe ROWE MULTI FORMULA SAE 5W-40 50200/50500/50501
Rowe Rowe Synt PD SAE 5W-40 50200/50500/50501
Rowe Rowe Synt RS DLS SAE 5W-30 50200/50500/50501
SCT Mannol Diesel TDI SAE 5W-30 50200/50500/50501
Shanghai Lizhong LUHU SAE 5W-40 50200/50500/50501
Shell Shell Helix Diesel HX7 AV SAE 5W-30 50200/50500/50501
Shell Shell Helix Diesel Plus VA SAE 5W-30 50200/50500/50501
Shell Shell Helix Diesel Plus VA SAE 5W-40 50200/50500/50501
Shell Shell Helix Diesel Ultra AV SAE 5W-30 50200/50500/50501
Shell Shell Helix Diesel Ultra VA SAE 5W-30 50200/50500/50501
Shell Shell Helix Ultra AX SAE 5W-30 50200/50500/50501
Sinopec Polar Star III SAE 5W-40 50200/50500/50501
Sinopec Ultra Gold SAE 5W-40 50200/50500/50501
Sonol Sonol Synt 505.01 SAE 5W-40 50200/50500/50501
SRS SRS ViVA 1 topsynth alpha LA SAE 5W-30 50200/50500/50501
Statoil Statoil LazerWay C3 SAE 5W-40 50200/50500/50501
Statoil Statoil PRO Synthetic C SAE 5W-40 50200/50500/50501
SWD swd PRIMUS DX SAE 5W-30 50200/50500/50501
SWD swd PRIMUS DXM SAE 5W-40 50200/50500/50501
Tecar Tecar Motorenoel 505 01 SAE 5W-30 50200/50500/50501
Tedex Tedex Synthetic Motor Oil SAE 5W-40 50200/50500/50501
Valvoline DuraBlend Diesel SAE 5W-40 50200/50500/50501
Valvoline Valvoline SynPower HST SAE 5W-40 50200/50500/50501
Valvoline Valvoline Synpower MST SAE 5W-30 50200/50500/50501
Valvoline Valvoline SynPower MST SAE 5W-30 50200/50500/50501
Valvoline Valvoline SynPower MST SAE 5W-40 50200/50500/50501
VAPS Vapsoil 505 01 SAE 5W-30 50200/50500/50501
Vapsoil VAPSOIL 505 01 SAE 5W-40 50200/50500/50501
Volkswagen Original Teile ® Volkswagen Special plus SAE 5W-40 50200/50500/50501
Wolf Wolf Masterlube Synflow PI SAE 5W-40 50200/50500/50501
Würth Triathlon Special PD SAE 5W-30 50200/50500/50501
Yacco Yacco VX 1703 FAP SAE 5W-40 50200/50500/50501
YPF Elaion Full Performance SM SAE 5W-40 50200/50500/50501
YPF Elaion Full Performance Tdi SAE 5W-40 50200/50500/50501
YPF Elaion Plus SAE 5W-40 50200/50500/50501
I'm Sorry
where are you getting that info from???:confused:
This is the published spec. I see no Mobil One O w anything!
Being in Foggy California I usually default to 20w50 (dino) oil and , Zero-w something sounds like it'd be used far North of the Arctic Circle...
Now, Mobil otoh, having accepted my 1981 S model VW Scirocco w/ 1.7liter moter recommends-
What's the right oil for my car?
Your vehicle has a specific recommendation.
The company that manufactures your vehicle recommends this Mobil 1 product, or has a special requirement.
Current Vehicle:
Year:
1981
Make:
Volkswagen
Model:
Scirocco
Engine Type:
4cyl. 1.7Liter Naturally Aspirated
Mobil 1 0W-40
Mobil 1 0W-40 is an advanced full synthetic motor oil that helps extend engine life by reducing engine wear and oil breakdown. Mobil 1 0W-40 provides outstanding performance under all operating conditions and meets or exceeds the warranty requirements of many leading car builders.
Huh. I've always defaulted to Mobil 1 15W-50 when using synthetic...
1 - 12 of 12 Posts
