Disclaimer: Any person, who decides to perform this modification, does so at their own risk.
I shall not be liable for any kind of damage, whether direct or indirect, resulting from use of
the information provided in this post.... Just don't do it!
There are many threads about how to disable the engine auto stop / start feature on new vehicles, this mod
is just one more way to do it, but more vehicle specific. I will leave at the end of this post links to other threads
that I found about this topic.
Parts:
To supply power to the Timer Relay I splice the cables going to the 12V auxiliary power outlet ( Same connection I used for my radar detector)
the brown wire is the negative, Green with Red is the positive. Always check voltage with Multi-meter.
DROK 12 Volt Timer Relay Connection Diagram
More information about how to dissemble center console and access this wires on other vehicles can be found HERE.
There are many different way to connect this wires, I like to strip about 2 mm of the insulation on the wire with a knife,
solder the wires and cover with electrical tape. Then I wrap all the wiring with Cloth Tape.
I secured the Timer Relay module with Velcro.
Programming the Time Delay Module:
Other Links:
SSAM Module Installation Instructions
SSAM Module Page link
Automatic Start Stop kill switch - The answer!! (Link 1) (Link 2)
Disable Start/Stop on Golf mkVII - VCDS tweak
Disable Start / Stop (MK2 Tiguan OBDeleven / VCDS Tweaks)
Parts:
- DROK 12 Volt Timer Relay: Amazon Link
- DROK 12 Volt Timer Relay: Instruction Manual
- Adecco Cloth Tape: Amazon Link
- Electric tape + soldering kit
[*]24 Gauge Wires: Amazon Link
- Product Function: P-2
- T-1 ( Timer 1 = time module will wait to turn the relay on) at 30 sec.
- T-2 ( Timer 2 = time relay will remain active) at 0.1 sec.
- Mode C: Timer starts when module is power on, after 30 sec. relay activates for 0.1 sec.
Other Links:
