Monsoon speed sensing volume on B5.5?
733 Views 4 Replies 3 Participants Last post by  Passat2001_5lover
Can my 2001.5 Passat GLS Monsoon radio w/in-dash CD be set so that the volume is speed sensitive? (volume goes up as speed goes up and volume goes down as speed drops). Can do this in my '97 Malibu w/stock radio. I searched on "volume AND Monsoon" as was unable to find this fact out. Thanks!
1 - 5 of 5 Posts
Re: Monsoon speed sensing volume on B5.5? (Passat2001_5lover)
Anyone???????
See less See more
For my 2002 GTI.. if you hold the "dolby" button in for a few seconds, you'll then get a set up screen. The track up/down knob will then set the speed-sensitive volume, 0-3. 0 being off.
Re: Monsoon speed sensing volume on B5.5? (JLJetta)
WOW, I never knew that...I'll go check that out when I get home!!!!
Re: Monsoon speed sensing volume on B5.5? (user name unknown)
THanks for the tip. I tried it and it did not work. MY dolby button is also my MIX (or shuffle) button when a CD is in. Perhaps the Passat I have is a different model than the 2002 GTI
If anyone with a 2001.5 Passat Monsoon am/fm/cassette has figured out if we have a way to adjust the speed sensitive volume, please post it.
Thanks!!
1 - 5 of 5 Posts
