I have racelands on my jetta and the lowered all the way. Are there anymore options to go even lower?
and bbs rsbags
whats a pump stop?cut pump stops,
my tires in the front are past the wheel wells and same with the backTake out helper springs, cut pump stops, remove perch. I'm guessing you haven't done all that cause I'm on racelands with 10 threads left up front and I'm pretty low.
Woops:laugh:whats a pump stop?
are the perches only in the back? what are the steps in doing that?Take out helper springs, cut pump stops, remove perch. I'm guessing you haven't done all that cause I'm on racelands with 10 threads left up front and I'm pretty low.
this:thumbup:Step 1 put car on jack stands
Step 2 pull wheels off
Step 3 pull coil overs off
Step 4 put tires back on
Step 5 lower car to the ground
Awww:heart:Mk4max is stupid low on racelands.. No excuses
Yes perches are in the rear, just drop the rear beam and pull them out from under the springare the perches only in the back? what are the steps in doing that?
on a serious note. when i had my aristos and couldnt get the rears lower, i had my full spare in the trunk, my moms old spare. and like 50 lbs of rocks. it did the job :laugh:cinder blocks in the trunk.
:laugh:on a serious note. when i had my aristos and couldnt get the rears lower, i had my full spare in the trunk, my moms old spare. and like 50 lbs of rocks. it did the job :laugh:
