1 - 9 of 9 Posts
I got the Autotech Rear Mount Inserts 10.199.023K as a present and I need instructions on how to install them. Any help is greatly appreciated. Thanks. http://****************.com/smile/emthup.gif
Re: Motor Mount Directions (SilverGolf1.8t)
Do I need to support the tranny? Will it fall out of the car if you undo the mount?
How long will it take an average person if they just drive the car up some car ramps and do it that way?
Re: Motor Mount Directions (Larry1.8TTU)
no the engine will not fall out. It will shift slightly.
The hardest parts will be reassembling and if you decide to replace the cylindrical mount that this one causes the mose vibration. This one is also the hardest to remove.
My suggestion is replace the two oval ones and see how it is.
Re: Motor Mount Directions (ACKTung)
Everybody says it's so easy and takes 15 minutes. I looked at the instructions on that website and I'm not so sure I can do that. Note: installing DieselGeek short shifter is the only thing I've ever done to a car.
Edit: Ok, I studied those pics more and maybe it's not so bad. I just had to brighten those images so I could actually see what was there.
[Modified by Gatorfreak, 10:46 AM 2-9-2002]
1 - 9 of 9 Posts
