Re: motor mount?? (verxdropper)
It's a little tricky, but I was able to reach around from behind the engine, over by the brake master cylinder. There was just enough movement of my long socket wrench to get one click of ratcheting. If that doesn't work, try a really long wobble extension, or get a Ujoint socket extension.
Sears sells a set of 3 (1/4" 3/8" 1/2") universal joints for 20 bucks, and has single, impact rated (MUCH stronger) Ujoints for like 12-14 each.
Harbor freight has a whole set of different wobble extensions for like $15.
But like I said, first time I removed the motor I just used the biggest ratchet I had and had barely enough movement from the back of it.
