The motor in my Jetta is shutting off at WOT on a somewhat random basis. The few times I have made this happen I decided to not let off the throttle right away and see what happened. The motor remained shut off as long as the throttle was in the WOT position, and then when I let off the throttle the motor would start running normally again. Then, immediately after this happened I would step back on the throttle to the WOT position and the motor would run all the way up to redline normally. The motor is not misfiring, it is completely shutting down when this occurs as long as the throttle is held in the WOT position. One time I did this I had accelerated up to about 70 MPH when it happened and I did not let off the throttle until the car had coasted down to about 50 MPH and then let off the throttle and the motor at that point restarted and ran normally. Any thoughts what might be causing this?
- Bob
