Quote, originally posted by Fla_Fox » |
I thought of mounting it under the rear deck but I was told that wasn't a good idea because of the heat dissipation. The amp would be mounted upside down unless I made some special brackets. I was told that the cooling fins need to be on top or, if the amp's mounted on the side, vertical to get good heat dissipation. I don't know if the position is that critical. The guy that told me this is somewhat of a perfectionist. |
