Re: MPG Display Fix (classicjetta)
{quote=dbrady]Have heard on here somewhere....(tried to search couldn't find it).... that there is a dealer programming fix to correct the discrepancy of calculated MPG versus MPG displayed on the MFD. Can anyone help me out?[/dbrady]It seemed quite relevant to the original post, since many of the same inputs for MPG also determine MPH (distance, time, speed ...)
However:
http://deviantspeed.com/jetta-...g-com
Was a very interesting read. What I don't know after reading this is whether changing the MPG affects anything else. I'd also be interested in knowing how the "winter tires" setting relates to any other readouts.
After thinking about it a bit, I can see why the manufacturer might want to under report miles per gallon via the trip computer. If you caused someone to run out of gas too soon because of a wrong computation, then you'd expose yourself to legal liability issues.
Better to have someone thinking they should get gas a little too soon rather than a little to late.
Things keep changing with cars. If you're misinformed and admit it, then you're only ignorant for a day. Dig your heels in over pride and you're stupid for the rest of your life ...
