Re: mud flaps self installation help (HeliMark)
quote:[HR][/HR]Just put the flaps "on", line everything up, and screw it on. Just need a little more elbow grease to start the screws.[HR][/HR]
The screws are "self-tapping" so it takes a bit of time for the tip to bite through the plastic. I had good results with a low speed drill with a screwdriver bit. Just give a little bit of pressure while the screw works - doesn't take long.
FYI, the current stock in Canada are Votex *front* and rear. "Votex" is molded into the plastic.
I think the reason that the rears don't use existing screws is that those screws seem to secure the lower valence/bumper making reassembly a bit of a pain. When I took the screws out of one side I had to realign the bumper while replacing the screws. It's much easier to screw into the thick fender well plastic.
Don't worry about it people... with a motorized screwdriver of some sort it takes less than 60 sec to secure both flaps. It takes longer to figure out the POS jack
[Modified by F1_Fan, 9:06 AM 11-26-2001]
