Multiple warning lights ABS,ECS,TPMS,Airbag,AFL - VCDS output attached
Hi,
First let me start by saying I have done some digging and I have found similar threads to this but they always go dead before a real solution has been given. Here is what is going on.
on 7/24/2020 While sitting in a parking lot with the engine idling I got a steering column lock error. The MIL came on along with written message. After about 10 minutes of driving it cleared and went away. I meant to scan it that night but didnt get around to. Fast forward to 8/7/2020 and while slowing down for a stop sign a flurry of messages came up. First the ABS then the ECS then the TPMS then adaptive front lighting and finally the airbag light, I was able to drive it normally but about an hour later it went into limp mode and I couldn't rev above 1500rpms and the Brake warning light came on. After letting it sit for a while and think about its life choices I started it up and limp mode was gone. I was then able to drive it home. From the scan it appeared to be related to a wheel speed sensor but I checked them and they all looked fine. I tried to log wheel speed via VCDS but the right rear showed error. I cleared the codes and they came back within a mile of driving. the next day I went out and this time I was able to log speed for all 4 wheels clear the codes and they stayed gone (but I knew they'd be back) sure enough while backing up today boom all the errors again save for the limp mode. Got it home, pulled the codes cleared it and everything is good again.
On the other threads their were lots of theories
1. The battery is going bad - In my case that could be a possibility since its 4 years old with 75K mi on it.
2. A wheel speed sensor is going bad or the reluctor ring in the bearing - again possible but from the logs there are a bunch of odd errors like wrong component installed but I never changed anything out. to it saying its the left rear one time then its the right rear.
3. The coolant shut off valve under/near the battery tray has sprung a leak and corroded a connector there. I pulled it all out and I didnt see any signs of a leak .
4. I found a small amount of water on the rubber mat in the passenger footwell after a heavy rain but I pulled the glovebox and cabin filter out and didn't see any signs of water ingress.
5. The steering position sensor or entire steering column has gone bad. I hope not since that is an expensive part but .... it seems to have all started with the column lock so it could be.
The car is stock. All preventative maintenance is up to date.
The VCDS output is bit confusing it says databus error but its not clear what the error is and that info is probably buried in the letters and numbers that come after the errors. Any insight would be greatly appreciated.
Thanks
I stripped away all the modules with no errors and I pasted in all the errors I logged for each module:
Thursday,13,August,2020,15:07:08:54054
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
Address 01: Engine (J623-CXCA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 D HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900122424002F1000
Shop #: WSC 00066 790 00149
ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
ROD: EV_ECM20TFS0205G0906259D.rod
VCID: 2F43CFDB76CE6AFEBA-807A
3 Faults Found:
17178 - Databus
U1123 00 [040] - Received Error Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
Engine speed: 1436.00 /min
Normed load value: 32.9 %
Vehicle speed: 14 km/h
Coolant temperature: 99 °C
Intake air temperature: 70 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.710 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
21323 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
Engine speed: 1417.50 /min
Normed load value: 34.5 %
Vehicle speed: 13 km/h
Voltage terminal 30: 13.750 V
Engine: operating status: PL
ECU_STATE: SYN_ENG_IGK_ON
Engine oil temperature: 101.0 °C
Time since engine start: 3792.0 s
T_ES: 0 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: Yes
STATE_ERR_ABC_PRED: 7
23131 - Implausible Data Received from ABS Control Module
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
Engine speed: 1396.75 /min
T_ES: 0 min
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 50806000000502
Coding: 01FA6BA13426096C007E020881C32980D62C9000408194B400430050C009
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 4BBBBB4BE21636DEB6-801E
0091 - Rear Right Wheel Speed Sensor
C101D 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
16417 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 191
Mileage: 119650 km
Date: 2020.08.07
Time: 19:03:14
0073 - Rear Left Wheel Speed Sensor
C101C 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:00
0075 - Rear Left Wheel Speed Sensor
C101C 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:51:17
0087 - Rear Right Wheel Speed Sensor
C101D 4A [137] - Incorrect component(s) installed
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 136
Mileage: 119644 km
Date: 2020.08.07
Time: 14:36:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:51:17
16401 - Tire Pressure Warning
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 157
Mileage: 108702 km
Date: 2020.03.03
Time: 18:30:10
C1146 02 [137] - Signal Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:25:14
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
1 Fault Found:
9483008 - Seat Occupied Recognition
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:16
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000031032003
Coding: 5500000000000000
Shop #: WSC 00066 790 07025
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3449C0B79FE84926C7-8060
1 Fault Found:
13637378 - Databus
U1123 00 [008] - Received Error Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
ELV State: 04
Information Clamps: 77 60
CoCo State: E0 01
WFS State: 1F 06
Vehicle speed: 13.40 km/h
Voltage: 78
AD-Value H-bridge: 3A
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
1048842 - Terminal 50
B11A4 12 [008] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 118602 km
Date: 2020.07.24
Time: 13:29:24
ELV State: 04
Information Clamps: 77 62
CoCo State: E0 01
WFS State: 1F 06
Vehicle speed: 62.05 km/h
Voltage: 76
AD-Value H-bridge: 39
CAN signals: 00
13637378 - Databus
U1123 00 [009] - Received Error Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:00
ELV State: 04
CoCo State: E0 01
WFS State: 1F 06
Vehicle speed: 37.97 km/h
Voltage: 78
CAN signals: 00
End-------------------------(Elapsed Time: 03:29)--------------------------
Hi,
Thanks
Revision: --H13---
3 Faults Found:
17178 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
T_ES: 0 min
U0415 00 [040] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
T_ES: 0 min
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 191
Mileage: 119650 km
Date: 2020.08.07
Time: 19:03:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:51:17
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 136
Mileage: 119644 km
Date: 2020.08.07
Time: 14:36:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:51:17
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 157
Mileage: 108702 km
Date: 2020.03.03
Time: 18:30:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 119595 km
Date: 2020.08.07
Time: 12:25:14
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:16
1 Fault Found:
13637378 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 191
Mileage: 120090 km
Date: 2020.08.13
Time: 13:39:04
ELV State: 04
CoCo State: E0 01
WFS State: 1F 06
Voltage: 78
CAN signals: 00
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 155
Mileage: 118602 km
Date: 2020.07.24
Time: 13:29:24
ELV State: 04
CoCo State: E0 01
WFS State: 1F 06
Voltage: 76
CAN signals: 00
13637378 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 136
Mileage: 119566 km
Date: 2020.08.07
Time: 11:54:00
ELV State: 04
CoCo State: E0 01
WFS State: 1F 06
Voltage: 78
CAN signals: 00
