Re: Must kill whoever changed clutch last. (negativl)
use some sockets on the engine stand to space the motor away fartherso there will be room for the clutch and longer bolts ........but if they are that tight u will prolly ring them off cause they are so small........and it might not be overtorked have u ever tried to get a bolt out that has green locktite on it only way is to use heat ...torch.....i would heat them anyway they will come rite out if u get flywheel hot enuf where the bolts are ...so u arnt tring to easyout them next week....i might try pb blaster penetrating oil first ....it dosent burn when heated so u dont have to worry about that
