1 - 14 of 14 Posts
I was driving around last night & when I put my headlights on I noticed my A/C controls did not light up.
Every other item in my car (including my boost gauge) worked.
Has anyone had the same problem on their 337/20th/GLI?
Thanks in advance!
Here's the pic that made you click on my thread
Re: My A/C Controls have no light!... (GTI*337)
You need to replace the light inside the fan switch on your hvac controls. That one bulb lights up the whole panel. Its a whopping $2.xx from the stealer.
If you goto MK4 faqs, there's a step-by-step procedure on exactly how to do it w/pics. I just did mine 2 days ago.
Re: My A/C Controls have no light!... (fahrfrumlosin)
same thing happened to mine, just tell the dealer to fix it, im sure its under warrenty
NOT under warranty. Bulbs are not after 12/12. Headlights are because of the day time running issue. All you have to do is remove the blower knob by pulling hard when it is set at the 2 position. Then use a piece of rubber hose with an inside diameter a little smaller than the bulb. Push it on the bulb, pull it out. Just reverse the process to install. Questions, let me know!
I has the same problem a while ago. I just gave it a love tap on the side of that console and it turned back on. I think that is in the volkswagen procedure book. Or maybe just mine.
Seriously...dkoelzer is right. Just smack the right side of the plastic surrounding the head unit and voila! It will be back on....almost guaranteed.
LOL
Re: (SpeedyGL-96)
Yep, the "love tap" procedure works well for me too. http://****************.com/smile/emthup.gif
Yeah, happened to me a couple of times. mine was a loose connection. One smack on the side of the center console, and voila, lighted climate controls once more......
Re: My A/C Controls have no light!... (schtebie)
mine has done it before on a 3 hour drive to providence, then on the way home. lights were back on. but last week they went out again, not sure if i wanna give it a love tap. i think ill just let the stealership worry bout this, if this isnt under warantee then thats retarted. not like its aftermarket or anything
Quote, originally posted by GTI*337 »
LOL, that really was the reason I clicked your thread... I feel lied to!
Re: My A/C Controls have no light!... (Usagisama)
Quote, originally posted by Usagisama »
iknow, i feel used
Discussion Starter · #14 ·
Re: My A/C Controls have no light!... (Grogthefrog)
Thank you gentlemen for all your input.
The "old love tap" didn't work. So tonight I'm gonna put on the wife beater t-shirt & really knock her around (just kidding)
When I get some time this weekend I'll pull her apart and check the bulb.
Sorry, for those who fell for my pic trick
1 - 14 of 14 Posts
