201 - 220 of 267 Posts
Discussion Starter #201
Update 12/02/19
New parts came in over the weekend. Probably install the 034 trans mounts sometime this week if I get a chance.
Update 12/08/19
Finally got around to replacing my oem transmission mounts with the 034 Motorsport street density mounts. Im pretty sure the oem mounts are original to the car and have almost 200k miles on them.
The Quick Jack sure does make things a lot easier.
Discussion Starter #202
Up to date
Done some interior upgrades today after I got back from Pull A Part and got what I could from a near mint B5 S4 with 75k miles on it. Snagged the gloss black exterior B pillars, illuminated facelift vents (which I will wire up later), S4 leather steering wheel (the yard wouldnt sell me the airbag, so I removed the radio controls and swapped over my airbag which has minor gaps due to a slight shape change in the wheel), leather wrapped hand brake cover and the vented inner fender liners (mine were busted and holes rubbed in them).
Discussion Starter #203
How bad my steering wheel was cracking
Discussion Starter #205
Pulled the A4 in the garage today and got to doing some work Removed the head and found some damage to cylinder one piston, 2 pieces of what look to be rubber from an old valve cover sitting in 2 of the oil jackets on the block. Going to take the head to the machine shop later this week and have it checked and cleaned.
Little comparison of the Frankenturbo F4hl to the Holset HX35
A friend of mine also 3D printed me some coil pack adapters. Need to smooth them out and throw some paint on them, hopefully they hold up to the heat cycles.
I think I have an extra euro valve cover if you want to try it. I swapped to it when I went to the new coils.
Photobucket is doing weird things again.
Discussion Starter #207
Nice. Id definitely be interested in it. Having a vented cover will help more with the crankcase pressure.
Discussion Starter #208
Some goodies arrived today, Tail wastegate and blow off valve, Deatschwerks 1000cc injectors. Treadstone manifold and Phenix injectors cups arrived last week.
Discussion Starter #209
Got around to bolting up the new oem oil pump. Only thing I had to bolt up, everything else is still dirty. I tried installing the oil windage tray, but its so deformed it didnt want to stay in place. Ive got another one thats still on my other block, hoping its in better shape. Ive got some sirface rust forming from where the block has been sitting, Ill get it all cleaned up later.
Discussion Starter #210 (Edited)
Been out in the garage all day making a mess of some wiring.
Why the exposed wires?
I ended up deleting the harness for the abs module, air conditioning, hood switch, windshield and headlight washer pumps. I traced the wires all the way into the cabin to the junction panel behind the driver kick panel.
I plan on deleting the maf, O2, evap purge valves from the engine harness as well.
Discussion Starter #211
Stripped the engine harness tonight of the old loom to freshen it up with some braided split loom and deleted the maf, o2 and evap purge valves, since Im going standalone and wont be needing them.
Discussion Starter #212
Got the engine harness all wrapped with split braided loom and Tessa tape. Very time consuming. Had some left over and wrapped up the harness coming from the driver fender well.
Discussion Starter #214
Nice.
Have you heard if the head is okay to use?
Its at the machine shop now. I went over everything with him and hes pretty sure its safe after milling and cleaning.
Discussion Starter #216
Thanks. I was surprised I had enough left from when I done the harness on my old MK2 a few years ago. I went through one full roll of the tape just on this harness.... I ordered 5 haha.
Discussion Starter #217
Sometimes its the little things that matter....
HPS silicone coolant block off cap for the turbo feed on the passenger side of the block. Since the Holset doesnt have coolant running through it, I needed a way to block off the feed port.
My brake lines from Allstar Performance came in today as well. Waiting on all of the fittings to show up so I can install everything.
Discussion Starter #218
ABS delete is pretty much finished, waiting on 1 fitting to arrive today. I didnt realize the rear lines under the driver frame rail were different, 1 male and 1 female, I had ordered both male fittings.
Passenger front going up into the false firewall
Driver front line going to false firewall
Rear line junction under the driver front frame rail
Wilwood Proportioning Valve for the rear lines and T for the front lines in the false firewall
Ill be working on cleaning up all of the dirt and grime and likely spraying some undercoating to make it look fresh.
Discussion Starter #219
Here is a list of things I ordered to delete the ABS.
Wilwood Brake Proportioning Valve with 10x1.0 ports https://www.jegs.com/i/Wilwood/950/260-12627/10002/-1
x5 10x1.0 to -3an male fittings (2 will go on the Wilwood Prop Valve, 2 for the front brake lines off of the calipers and 1 for the rear brake line under the driver side frame rail) https://www.chasebays.com/collections/an-fittings/products/3an-to-10-x-1-0-convex-male-brake-adapter-euro-chassis
x1 10x1.0 female convex to -3an male fitting (rear brake line under the driver side frame rail) https://www.pegasusautoracing.com/productdetails.asp?RecID=4193
x2 12x1.0 to -3an male fittings for the brake master cylinder http://www.jdaent.com/product-p/jda-458014.htm
x2 -3an 3 way fittings (one for rear brakes and one for front) https://www.chasebays.com/collections/an-fittings/products/3an-male-tee
x2 15" -3an braided lines (coming from master cylinder, 1 will go to the 3 way for the rear brakes, 1 will go to the prop valve for the rears) https://www.jegs.com/i/Allstar-Performance/049/ALL48416/10002/-1?trk_msg=F4DEA4K0TBPKT67FKEGNHFHHLC&trk_contact=N315PP2A71U0T99RFSJO8BJ1SS&trk_module=tra&trk_sid=I5TMGRR6VQ4G9BA66PS93MM7QG&utm_source=listrak&utm_medium=email&utm_term=Product&utm_campaign=Transactional&utm_content=Shipping+Confirmation
x1 12" -3an line to go from the prop valve to the 3 way for the rear brakes https://www.jegs.com/i/Allstar-Performance/049/ALL48361/10002/-1?trk_msg=F4DEA4K0TBPKT67FKEGNHFHHLC&trk_contact=N315PP2A71U0T99RFSJO8BJ1SS&trk_module=tra&trk_sid=I5TMGRR6VQ4G9BA66PS93MM7QG&utm_source=listrak&utm_medium=email&utm_term=Product&utm_campaign=Transactional&utm_content=Shipping+Confirmation
x1 24" -3an line from the passenger front caliper to 3 way https://www.jegs.com/i/Allstar-Performance/049/ALL48430-24/10002/-1?trk_msg=F4DEA4K0TBPKT67FKEGNHFHHLC&trk_contact=N315PP2A71U0T99RFSJO8BJ1SS&trk_module=tra&trk_sid=I5TMGRR6VQ4G9BA66PS93MM7QG&utm_source=listrak&utm_medium=email&utm_term=Product&utm_campaign=Transactional&utm_content=Shipping+Confirmation
x3 30" -3an lines (one for the driver side caliper to 3 way, 2 for the rear lines under the frame rail to the 3 way) https://www.jegs.com/i/Allstar-Performance/049/ALL48430-30/10002/-1?trk_msg=F4DEA4K0TBPKT67FKEGNHFHHLC&trk_contact=N315PP2A71U0T99RFSJO8BJ1SS&trk_module=tra&trk_sid=G7D3B79OJ4HLJOQE01A95QUQI8&utm_source=listrak&utm_medium=email&utm_term=Product&utm_campaign=Transactional&utm_content=Shipping+Confirmation
The length on some might be a tad bit overkill, but I wanted to play it safe.
That's awesome. I wondered why you ordered a bunch of random allstar lines when there's so many SS brake line kits.
So much extra room in the bay without the ABS!
