1 - 20 of 51 Posts
Started with this: http://forums.vwvortex.com/zerothread?id=3169451
Today I was just going around the corner to get some food and right before my street on the return trip my car basically died..
All of a sudden I heard like a bolt or something go flying under the car and it just REV'D hard.
My engine was still running but I could not get it to grab any gear, it would just rev..
HELP
pic of the car that just died
Re: My car just crapped out, is it my tranny? (85vrcoupe)
my friend told me it is my clutch
I was able to start the car just now, put it in first, let out the clutch and it just rev'd, I didnt move.
Quote, originally posted by 85vrcoupe »
i would check the axles first
Yup http://****************.com/smile/emthup.gif I would check the axles, then possibly the clutch and pressure plate.
Re: My car just crapped out, is it my tranny? (CHRGD_MK2)
pete.. when you put the car in gear, and let it out and give it gas if the speedo moves its probably and axle.
so just try that first. thats what happened to me with my car.
Re: My car just crapped out, is it my tranny? (Splisks)
Quote, originally posted by Splisks »
if it was the clutch wouldnt you still be able to get all the gears except the one(s) thats busted
Check your axles. When one breaks, the car won't move (you can put it in gear and let the clutch out and nothing will happen)...that is, unless you have an LSD
seems like axel because the speedo moves when I rev it in first
I think that could hurt the differential, don't let it sit still in gear without the clutch pressed for long...
Discussion Starter · #13 ·
jacked it up, the driver side wheels moves with so much ease while the passenger doesnt.
So I broke my driver side axel?
Discussion Starter · #14 ·
Re: My car just crapped out, is it my tranny? (anon_az)
Quote, originally posted by anon_az »
I did that test, really fast.
if you dont know if its your axle. just turn your wheel and look under the car or through the side of the wheel.
you will either see a bunch of grease or it snapped
Discussion Starter · #17 ·
Re: My car just crapped out, is it my tranny? (severed)
Thanks for all the help so far guys, means a lot.
I jacked up the car and it seems like it is the driver side for sure. Its starting to get dark and its in the street, so I cant do much more checking tonight.
1 - 20 of 51 Posts
