Sphak, So just wanted to throw out my experience with the 09 G I have MK 6 2012 Jetta with 148,000 mi. I first felt this shift bump between shifts like 3rd to 4th gear after a long road trip in the middle of last summer. I would say heat definitely plays a role in this shifting problem it has gotten worse over the last 6 months.. now it is sometimes a scary shift bump like it's going to rip the car apart. anyhow I have stage 1 ECU and TCU tuning from integrated engineering and my car when cool still to this day as long as it's cool and not warmed up alot it runs 5.8 seconds 0 to 60 It runs like a freaking raped ape it's awesome. however once it's warmed up for 10 or 15 minutes it does that crazy shift bump could be between first and second could be third fourth could be the 6th it doesn't matter it does it eratically when it's hot. I'm going to try some of this shift learning that I've been reading about here with the TCM but otherwise I'm just going to replace this whole motherfng unit and keep on asking
Thank you for the postings. They lend some alternative insights into the 09G. This would have been much more appreciated 3 years ago beofre I made a tool, but that is how it goes. The pdf is also nice, however, realize that this transmission doesn't need any special tools, besides the one requred to fill the pan and, of course, a scanner. If you have general transmission rebuilding tools than you will set to go. Also, in regards to the VB replacement, I wouldn't be too worried as the chance of you getting a VB with issues is rather slim. I have built 6, 09G units and haven't had such a problem, but it is possible. Now there are ways to fix these issues, but I have omitted them in the postings here because of the liability of sorts. Since this issue of 09G VB's is such a big topic I may write a post focused solely on my experiences with this VB, such as identification, function, and troublespots and what your options are. Again, I have only rebuilt 6 of these particular units but I have been intrigued with this unit because of how mysterious it is. Aisin-Warner don't really have good luck with VB's and the 09G is no exception, however, AW makes other transmissions that have many, many more VB complaints than the 09G! At the end of the day, in terms of high-quality foreign transmissions, ZF is still king. If you think that such a post specifically focusing on the VB information mentioned above is good idea, let me know. Anyone can respond to this as well. Thanks again for the information in your last post.
