1 - 16 of 16 Posts
Here's the whole story. a buddy bought this 76 bus in 07, it came without engine or trans for 1k. He than bought a type 4 stroker 94x78mm with dual 44 webbers, 3-rib freeway flyer and some other stuff for like 4k. I installed the engine and trans but since the bus came in fuel injection for some reason I couldn't figure out the alt wiring. So he ended up bringing it to someone who does the aircooled thing and 1200 bucks later it was completely rewired with a webber electric fuel pump etc. The guy mentioned it needed rear brakes, my buddy refused to spend more money. 6 months down the road the brakes go! It sat for the next year!
I bought this 2 weeks ago for 1k!!
So far I have adjusted valves, messed with timing and gave her a good wash!
It needs:
valve readjust
tune up
Lucas or seafoam?
carb adjust
rear brakes
some rust repair
Uploaded with ImageShack.us
and the bad!
Nothing wrong with it that can't be addressed. Nice buy indeed. :cool:
Discussion Starter · #10 ·
Today I got it running better. I ran some new gas with lucas mixed in and messed with the timing. It had a backfire as revs were coming down. My friend told me to turn each mixture screw 1/4 inch and run hard. It made a major difference. Now its waiting till I have some extra cash for a complete tune up.
I have some questions
Can I run a SVDA distributor off the 44mm dual webbers? ( now have a 009 electric dizzy)
How much of a difference would a pertronix flamethrower coil make?
What wires?
what oil filter and weight oil? (I live a Georgia never really gets that cold)
Dayo Shaggy :) ,
Can I run a SVDA distributor off the 44mm dual webers? ( now have a 009 electric dizzy)
Not recommended;) .
Not much, the blue coil you already have should be plenty adequate;) .
What wires?
The stock ones you already have should be fine as long as you keep them reasonably separated from each other in an orderly fashion http://chircoestore.com/catalog/smf/index.php?topic=8553.msg55413#msg55413 ;) .
An 021-115-561-B http://www.google.com/search?hl=en&...0...1ac.1.24.heirloom-hp..7.6.646.SsG2w5ABL8I is stock or you could probably fit in the larger 068-115-561-B http://www.google.com/search?q=068-.....1ac.1.24.heirloom-serp..4.2.206.XEmMzvH-awo , that's the one;) I used when I was running a filter
They're both the same larger diameter but the 068 has ~twice the filtering capacity compared to the 021 & I'm pretty sure that there's enough room down below in order to accommodate it
from
http://www.ratwell.com/technical/Microfiche.html .
I always used Castrol 20/50W non synthetic oil;) .
:beer::D
:D
Oh and how do I attach the ac compressor to the engine?
Air conditioning was always an aftermarket afterthought BITD Shaggy :) .
There were both DPD http://www.google.com/search?hl=en&...0...1ac.1.24.heirloom-hp..1.5.545.F7BOUwhzpQc & VPC http://www.google.com/search?q=vw+v....1ac.1.24.heirloom-serp..16.1.124.TuTkYyrDbE8 units used, each had their own bracket & pulley & belt systems;) .
See what ID info you can pull off of that compressor & dash vent assembly then best match it to the system in the searches I just did;) , from there it's pretty much fabricating new brackets if they can't be sourced from a wrecking yard & keep your eye open on other VW Type IV & Porsche 914 sources as well;) .
Have it upgraded from an R12 to R134(all new O-rings & expansion valve;) ) & make sure;) that your engine & trans mounts are up to date so that it doesn't shake itself apart;) (the brackets break quick:eek: when there's too much vibration;) ).
:beer::D
1 - 16 of 16 Posts
