1 - 10 of 10 Posts
Discussion Starter #1
I finally got my dyno post here!!
I did it two weeks ago!!
And I've just bought a Schrick VGI,
Wonder how much more number can I get with the VGI??
I thinking of getting MkIV head gasket too!?
what number will I get after these two mods?
[Modified by Be Lippy!!, 2:37 AM 12-3-2002]
Banned
Re: My first dyno!! (Be Lippy!!)
those power adders give you about what you make @ the flywheel, i dunno, you should be making more? or is that about right?
The VGI wont give you much hp, but it'll give you a nice lumpo of trq between 3-4K.
Your number are not bad, but I am not sure what that ABT header is doing. How much was that thing?
What kind of dyno was this, dynojet, mustang?
The head gasket will raise your compression by .6 i think or something like that, so you should get a couple hp from that if anything. Pickup a T2 lightened crank pulley. I would have said screw the VGI, and get otherstuff. But you'll be happy if its daily driven.
Also did you get the SAE corrected numbers?
Numbers
Pretty good numbers there, Be Lippy. Now to make REAL power you need a big-valve head!
VGi makes a HUGE torque difference and around 5 horsepower by itself. It matches the 268 cams very well. I can get it cheap, by the way!
Re: Numbers (Sleeper 3.0T)
Decent #'s http://****************.com/smile/emthup.gif
Discussion Starter #7
Re: My first dyno!! (GTIVR6RACER4EVER)
Also did you get the SAE corrected numbers?[HR][/HR]​
I did it on a dynojet, what is the deifference between a dynojet and a mustang?? And what is SAE corrected numbers??
I didn't know ABT made a header for the VR6. What kinda power gains could you feel when you installed it?
Discussion Starter #10
Re: My first dyno!! (vrsixxx)
quote:[HR][/HR]I didn't know ABT made a header for the VR6. What kinda power gains could you feel when you installed it?[HR][/HR]​
Feels like It produces more power at high end, but the most noticeable gain is the noise. It sounds alot wilder than the stock header!!
1 - 10 of 10 Posts
