My project is nearing completion yet again, so figured I would assemble another build thread to show the world what I did to my poor little 1.8T and what it yielded. If I don't mention it, it's stock AWP 1.8T. I won't get into any of the body, suspension or brake modifications here since it is the 1.8T forum, but the car is very light and is specifically built for SCCA FP Solo competition as well as HPDEs.
For more information on the non-engine modifications, take a look at this thread I started in the autocross forum: http://forums.vwvortex.com/showthread.php?6126117-My-MK4-GTI-Setup-Thread
NEW BUILD
Engine:
-ITG 3" cone filter
-VR6 MAF housing with an AWP MAF sensor
-FFE custom aluminum turbo inlet pipe
-N75 J valve
-Forge Evo 7 diverter valve
-GonzoTuning/GTS GTTx K04-02x Turbo, port matched to manifold by FFE (https://www.gonzotuning.com/hardware/mk4/gtt/)
-Forge adjustable wastegate actuator, customized for the K04 by FTD Motorsports and FFE
-High flow cast exhaust manifold, ported and machined by FFE
-42DD MK4 K04 downpipe with test pipe and 3 O2 bungs
-FFE custom 3" side exit aluminum V-banded exhaust with 3.5" Vibrant aluminum muffler
-FFE custom aluminum intercooler charge pipes
-BSH FMIC core
-SEM small port passenger side intake manifold
-OEM R32 throttle body
-iABED Industries 5.7L motorsports baffled oil pan
-830cc Siemens injectors
-Hitachi bolt-down "E" coil packs
-NGK BKR7E .028" plugs
-AMSoil 5w40
-E85 fuel (also maps for 93 and 100 octane)
-DeatschWerks DW65v in-tank high flow fuel pump
-Integrated Engineering Deleted SAI/N249/EVAP + AC
-GonzoTuning Stage 4 software
-Valeo 3 row radiator, custom plumbing and flanges to delete heater core
-Mocal 19-row oil cooler with -10 Aeroquip braided hoses and fittings (factory exchanger deleted)
-eBay 500cfm fan behind oil cooler
-034 Motorsports catch can
-Eurojet lower PCV hose
-IE connecting rods
-Fluidampr crank pulley
-Shine Racing Service custom solid aluminum upper motor mounts, FFE Racing motor plate to replace the factory dogbone mount
-Prosport gauges for oil press/oil temp/boost/EGT and an Innovate MTX-L wide band air:fuel
Transmission/Drivetrain:
-2005 02J with a Peloquin LSD
-Raxles axles
-ClutchMasters FX400 6-puck clutch kit with steel lightened flywheel
-DieselGeek Sigma5 short shifter
-billet shifter mount bushings
PREVIOUS BUILD
Engine:
-ITG 3" cone filter
-some crappy silicon TIH
-N75 J valve
-Bailey's DV
-GonzoTuning GTT Turbo (https://www.gonzotuning.com/hardware/mk4/gtt/)
-Godspeed high flow cast exhaust manifold
-Godspeed 2.5" downpipe
-TT/Borla 2.5" exhaust
-Alamo Autosports hard boost pipes
-EvoMS FMIC
-AMSoil 5w40
-Walbro 255lph inline pump w/ USRT harness
-Setrab 19-row oil cooler with -10 Aeroquip braided hoses and fittings
-Eurojet PCV hoses
-IE connecting rods
-034 track density motor mounts
-Raxles axles
-billet shifter mount bushings and brass cable end bushings
-TT short shifter
New Dyno:
Still at 27 PSI with a little more timing up top than before. Performed on a very hot and muggy day at FFE Racing.
Old Dyno:
Was done at 27 PSI with relatively conservative timing. In a couple weeks I'm going to run the same setup on the Dynojet at ForceFed, then from there bring the boost up a little bit (~30) and dial in the timing more. I'm super happy with the fat powerband and driveability of the car so far, just what I was shooting for when I took the leap from stock turbo.
NEW BUILD
Engine:
-ITG 3" cone filter
-N75 J valve
-BSH FMIC core
-AMSoil 5w40
-IE connecting rods
-Raxles axles
PREVIOUS BUILD
Engine:
-ITG 3" cone filter
-N75 J valve
-Bailey's DV
-EvoMS FMIC
-AMSoil 5w40
-Eurojet PCV hoses
-IE connecting rods
-Raxles axles
-TT short shifter
New Dyno:
Old Dyno:
